Home » Support » 3D Printing » Lens moulds
Lens moulds [message #37277] Mon, 24 October 2011 22:33 UTC Go to previous message
avatar wxs  is currently offline wxs
I'd like to use Shapeways to print moulds for some lens prototypes I'm working on. The curvature is fairly subtle (say a 20-40 micron height difference from highest to lowest point). I imagine that even FUD is too imprecise for that if I build with the lens facing "up" in the z-direction, as according to this:
http://www.shapeways.com/forum/index.php?t=rview&th=6108 &goto=32610
the layers are 31 microns thick.
I could, however, rotate my mould 90 degrees, so that the precision that matters is on the x-y axes.
What kind of accuracy is there in the x-y axes? I don't imagine that the minimum feature size is the correct number for this, as that speaks to the ability of the material to maintain a small ridge. Rather I want to know how precisely it will match my desired curvature. The surface will be gradually varying, so there are no fine ridges.
Does anyone have any input?
Thanks.
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:Is this accurate?
Next Topic:Printing multiple objects (stupid question)
Goto Forum:
   Go
Current Time: Tue May 21 17:11:43 UTC 2013
