| 2 issues with co-creators [message #36428] Tue, 11 October 2011 17:38 UTC |
Hi all,
I had to face recently two issues with co-creators.
First the error message for co-creators is not explicit.
There was a problem when I uploaded one of my co-creators and I got the following message:
| Quote: | Hello,
We are sorry to report that there is a problem with your personalized template
Happy Event Bead, Event Bead Sky.zip.
It did not pass the check model_correction.
This message is typically of no use.
I uploaded the very same model in my shop (without going through the co-creator mechanism) and this time I got this message:
| Quote: | We just finished processing your product, Event Bead Sky, and ran a few checks on it to make sure your product can be printed.
Unfortunately, we were not able to process and thus print your product. The error message was:
Your object has not the correct size.
The size is 0.00 x 0.00 x 0.00 cm / 0.00 x 0.00 x 0.00 inch.
OK, now I can do something. Knowing the problem, you can fix it.
Can we have the same level of detail on message error for co-creators as for standard models?
Second, when i tried to fix the issue, I went back to the co-creator customization page and the customization texture was not visible anymore:
This is a huge bug. I had saved the image before, so I was able to go on anyway, but what if I did not keep a copy of this image? It would have been impssible to finish the customization.
Anyone noticed the same things?
