Home » Support » 3D Design » Many questions from a 1st time user
Many questions from a 1st time user [message #35371] Wed, 28 September 2011 23:33 UTC Go to previous message
avatar frank26080115  is currently offline frank26080115
This will be my first time getting something made with 3D printing.
My design is basically a electronics enclosure, it will have buttons which will also be 3D printed
The material I will choose will probably be the black detailed plastic
I did consider another company, they had a minimum volume requirement that made it annoying to create buttons. Do you have any such requirements?
I am using SolidWorks. Which axis do I need to specify as the vertical axis? Or is this determined by your machine automatically?
Is the volume of the design calculated using the amount of model material or the model material plus the supporting material? If it is the combination of the two, is it possible to optimize the cost by putting multiple designs into one file in a compact way?
Is it better to upload each solid object as a single file? Or can I combine all the solid bodies into one file?
Thank you.
Read Message
Read Message
Read Message
Previous Topic:Hollowing an object - Methods - Printing - File extenstions
Next Topic:Can i give seperate guideline for color information, instead of using *.wrl file?
Goto Forum:
   Go
Current Time: Wed May 22 11:55:41 UTC 2013
