Geared D6
Geared D6 [message #27940] Fri, 20 May 2011 20:06 UTC Go to previous message
Shapeways Crew
The Geared D6 did finally arrive! It is in Frosted Ultra Detail.
/openfile/249527/photos/photo40894.jpg
/openfile/249527/photos/photo40892.jpg
/openfile/249527/photos/photo40895.jpg
Even if it is not fully functional, I am very happy with the result: none of the gears get fused although the very small clearances.
Nevertheless the gears of the number 6 are not turning at all. But except 6, all the gears of the other faces are turning a little bit when you turn the big gear of face number 1.
Unfortunately I don't know really what to do. I have the feeling that this is due to too much clearance on the axes, but it is perhaps just that the movement cannot be transmitted through so many gears: from 1 to 3 and from 3 to 6.
I will probably try to reduce some clearances and to have less teeth in the internal gears (compared to the external) and hope this will be enough to fix the issue.
I will post a video soon.
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:1st model arrived :)
Next Topic:Metal Skull Die by Artfulshrapnel
Goto Forum:
   Go
