White Detail: Layer problem?
White Detail: Layer problem? [message #23216] Mon, 31 January 2011 05:45 UTC Go to previous message
avatar WildRoo  is currently offline WildRoo
I received several prints of models I ordered and at first thought they looked good. Upon opening the bags I discovered what is for me a Big problem: I can not only See the individual layers on the model, I can Feel them.
There were 3 parts on one print: one doesn't matter because of the design. The other two have many flat edges on them and this is where the edges are most visible.
One was at an angle to the print direction and has a slight fuzzy look to it. The edges on it are rather smooth instead of sharp.
The second was printed parallel to the print direction. Each flat side surface shows visible stepping on the model which you can feel with your finger.
The above two cubes are 0.75" each.
I received another item in White Detail that is 3 inches long (printed in the "width" or x/z direction) and it has lines running horizontally on the long slightly curved side but these do not exist in the areas where there's more shaped details.
Is this normal for White Detail?
[Updated on: Mon, 31 January 2011 05:48 UTC]
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:design accepted, but now unprintable?
Next Topic:Question regarding printing small parts
Goto Forum:
   Go
