Home » Community » Work in progress » New Dice
New Dice [message #19911] Sun, 31 October 2010 15:26 UTC Go to previous message
Hi all,
As discuss in the topic "Designing dice for dice snobs", I designed today a new Average D6 where you have to make the average of 4 faces of an octahedron, to find the result of a regular D6.
index.php?t=getfile&id=5704&private=0
The faces of the octahedron are numbered 1, 1, 1, 1, 2, 4, 8, and 10.
Here are the operations :
(1 + 1 + 1 + 1)/4 = 4/4 = 1
(1 + 1 + 2 + 4)/4 = 8/4 = 2
(1 + 1 + 2 + 8)/4 =12/4 = 3
(1 + 1 + 4 +10)/4 =16/4 = 4
(1 + 1 + 8 +10)/4 =20/4 = 5
(2 + 4 + 8 +10)/4 =24/4 = 6
The positions of the virtual 1, 2, 3, 4, 5 and 6 are the regular positions of a D6 (opposite sides sum to 7).
This die is 21.5 x 21.5 x 21.5 mm. The diameter of the wire of the frame is 3 mm so you can print it in Stainless Steel. The price will be less than $25.
It has not been prototyped yet (as soon as I will do, it will be in the "It arrived" section).
More informations soon about other variations of this design.
[EDIT]
if you choose 1, 1, 1, 1 for the four upper faces of the octahedon, you still have several choices for the lower faces (all numbers being larger or equal to 1):
- 1, 5, 9, 9 (all numbers are in the form 4k+1, but I did not choose this one because 1 is repeated again and 9 appears twice)
- 2, 4, 10, 8 (opposite numbers sum to 12, the one I chosed)
- 3, 3, 11, 7 (all numbers are in the form 4k+3 unlike the four 1 of the opposite faces, I did not chose this one also because 3 appears twice)
- 4, 2, 12, 6 (I prefered the other one because the maximum number is smaller)
- 5, 1, 13, 5 (all numbers are in the form 4k+1, I did not choose this one because 1 is repeated again and 5 appears twice)
  • Attachment: Avg_both.jpg
    (Size: 78.48KB, Downloaded 653 time(s))
[Updated on: Sat, 27 November 2010 07:36 UTC]
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:new patterns on the canvas wrap
Next Topic:New I Ching and Lost pendants
Goto Forum:
   Go
Current Time: Tue May 21 17:11:44 UTC 2013
