Mechanical design of springs incorporated into object
Mechanical design of springs incorporated into object [message #69741] Thu, 13 June 2013 08:21 UTC Go to previous message
avatar darenw  is currently offline darenw
For one product, I'd like a part to be held within a larger frame, and to let the inner part rotate by (probably) 20 degrees or so. It will not be a separate free-moving part, but joined to the frame, with limited mobility. I'd like to join it by a strip or wire of material, so the whole thing is one piece. What should I know about designing this strip or wire? How flexible is each of the materials I could use? How flexible is a long thin part? Are there graphs or empirical formula to estimate spring constant from geometry? The image shows, crudely, some types of springs I'm considering. The inner disk will rotate about the red axis (by means not shown) but only a few degrees.
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:My flute model isn't quite hollow
Next Topic:Just how flexible is WSF?
Goto Forum:
   Go
