3 wheeled roadster - Repair and color needed - hire
3 wheeled roadster - Repair and color needed - hire [message #64864] Mon, 25 March 2013 19:56 UTC Go to previous message
avatar dkeager  is currently offline dkeager
Need to hire someone for help.
I've created the model to about a 7" size to be printed in sandstone. It's still a pretty complex model and I know still has a lot of holes. I'm unable to figure out how to fill/repair the holes for printing, 'Close holes' still didn't repair them correctly. There's probably several internal surfaces and possibly some untrimmed ones. There a screen shot of the results from Netfabb. You can see my rim design gets surfaced over after repairing.
All surfaces are bigger than 2mm. The steering wheel is about 2.25mm thick. I suppose the details in the drivers fingers would be lost, but that's ok. I'm guessing supporting this vehicle on 3 wheels would be risky structurally, so I've added 3 other subtle supports underneath.
Is there someone I can hire to make these fixes, ensure the colors are applied in the correct places and ensure the model is good for printing? I can supply the Obj when needed. The file was originally created in Autodesk Alias so I have the original wire/IGES or STEP if that's easier.
We need a quick turn around as well,
Thanks.
Read Message
Read Message
Previous Topic:Have files that need split up/ minor corrections made.
Next Topic:Scale size laundry basket
Goto Forum:
   Go
