G-scale playtime
G-scale playtime [message #61495] Wed, 06 February 2013 21:57 UTC Go to previous message
avatar Jean-PhilippeBlain  is currently offline Jean-PhilippeBlain
New prints in polished WSF arrived today from Shapeways, and made me come back from work earlier. Wink
Both I and my 8 years old boy were very excited.
Pieces all look very nice ! For the smaller ones I have been using a 1mm thick small loop.
index.php?t=getfile&id=26779&private=0
Two of the pieces were due to fix some older G-scale switches, with too large gaps, that made locomotives go of the rails.
I made a mess on this one. I guess I was out by a few degrees when I measured angles on the switch.
But the material is flexible, so gluing it should work.
index.php?t=getfile&id=26780&private=0
All the rest is about allowing my son using Lego bricks together with the G-scale track in his room.
This includes some couplers to be used with others cars. The advanced coupler version has a hook, but I am not sure how it will resist over time as I fear the spring part is a bit too fragile.
index.php?t=getfile&id=26781&private=0
I also got axle boxes for metal wheels - this will need some post-processing work to lower friction, as I designed the piece a bit too tight.
index.php?t=getfile&id=26782&private=0
That's it for now ! Let's play !
index.php?t=getfile&id=26783&private=0
[Updated on: Thu, 07 February 2013 05:13 UTC]
Read Message
Read Message
Read Message
Previous Topic:''Pulse'' Modern Cross
Next Topic:Silver Valentine's Forget-MeNot Flower Heart
Goto Forum:
   Go
