Just how flexible is WSF?
Just how flexible is WSF? [message #5902] Mon, 17 August 2009 08:20 UTC Go to previous message
avatar Tommy_2Tall  is currently offline Tommy_2Tall
Hi!
I know I could make some reference parts and place an order to answer this questions my self but I'm trying to get the guess-work out of my very first models.
If someone could share their experience with WSF that would be great.
How flexible/stiff is WSF plate with a thickness of 1mm, 2mm, 3mm, 4mm, 5mm, etc?
How flexible/stiff are cylinders/square bars with those same thicknesses/diameters?
At what width are they:
  1. Flexible with no force applied (flexing of their own weight)
  2. Flexible with slight force applied
  3. Flexible with significant force applied
  4. Unflexible and "woodlike"
Can we (the community) make some sort of "flexibility matrix" that rates various basic shapes on that scale to help newcomers with little knowledge about WSF?
(That would make the need for material reference models somewhat smaller Smile )
The reason I'm asking is because I'm trying to design a "living hinge" along the long side of a (stiff) lid that is appr. 5*100mm in area and I have no idea if 1mm for the hinge area and 2-3 mm for the lid will work.
Another model I'm working on includes a square network of 1x1x10mm rods (square or subsurf'ed)..
Will that be strong/flexible enough to keep stuff inside a small confined box or will it break if I just poke it gently with my fingers?
How thin can you go designing a mesh/net wall, with regards to the "wall thickness" and "minimum detail"?
Will the net be counted as details as long as the frame around it is 1mm or more?
[Updated on: Mon, 17 August 2009 08:36 UTC]
Read Message
Read Message
Read Message
Previous Topic:Mechanical design of springs incorporated into object
Next Topic:How to make an iPhone 5 case
Goto Forum:
   Go
