Home » Community » It arrived! » A Tale of Two HO Wheel Stops
A Tale of Two HO Wheel Stops [message #58775] Mon, 17 December 2012 23:58 UTC Go to previous message
Here's a comparison of essentially the same 3D design printed in two different materials - WSF and FUD.
The first pic is a rendering of the 3D design; the WSF part is slightly thicker to meet the 0.7mm min wall thickness required (FUD only requires a minimum 0.3mm wall thickness).
The second pic shows the delivered prints after spray painting mounted on Atlas HO Code 83 Flex Track. On my screen the parts in the pics are magnified to ten times actual size.
Surface details in WSF are there but vague and grainy; FUD is very sharp. Unsurprisingly the cost of the FUD parts is double the price of WSF.
If you shrink the pic of the painted parts to 10% (roughly actual size for the parts) all that extra detail in the FUD print disappears and both parts look alike.
The FUD prints are worth the extra cost if you're viewing them from 18 inches of less distance and can see the detail; at greater distances WSF is the way to go.
FUD prints are for sale here:
http://www.shapeways.com/model/832945/6-bolt-wheel-stop-fud- ho-10pk.html
http://www.shapeways.com/model/832902/6-bolt-wheel-stop-fud- ho-20pk.html
WSF prints are for sale here:
http://www.shapeways.com/model/774527/6-bolt-wheel-stop-ho-w sf-20pk.html
http://www.shapeways.com/model/778905/6-bolt-wheel-stop-ho-w sf-40pk.html
index.php?t=getfile&id=24495&private=0
index.php?t=getfile&id=24496&private=0
[Updated on: Tue, 18 December 2012 00:03 UTC]
Read Message
Read Message
Read Message
Read Message
Previous Topic:Ceramics just arrived
Next Topic:The Giver and Last Stand
Goto Forum:
   Go
Current Time: Sun May 19 01:40:27 UTC 2013
