Home » Support » 3D Printing » Texture Map size for Full Color Sandstone?
Texture Map size for Full Color Sandstone? [message #53873] Tue, 11 September 2012 14:51 UTC Go to previous message
avatar MikeP  is currently offline MikeP
Is there an optimum size for textures to use with full color Sandstone?
I had a print done last month and I used a 24bit 1000x1000 image. The results were good but would a higher resolution be better or (as I suspect) does the printer resize the image before using it?
If the printer does resize the image I'd like to know the resolution so I supply it in the correct size myself.
Read Message
Read Message
Read Message
Read Message
Previous Topic:Dimensions
Next Topic:minimum size for a good polished?
Goto Forum:
   Go
Current Time: Sat May 25 11:43:03 UTC 2013
