Home » Support » 3D Applications » 3dsmax units setup
3dsmax units setup [message #53341] Thu, 30 August 2012 00:04 UTC
avatar Jchalfant  is currently offline Jchalfant
Howdy,
I just recently noticed that it seems to be a pretty big deal if you keep your units setup as 1unit = 1inch... this will cause a lot of errors when uploading to shapeways.
The correct scale settings inside 3dsmax should be 1unit = 1mm. This is under Customize > units setp > system units in 3ds. Real important 1unit = 1mm... or there's a big chance your model will fail the automated checks.
I say "recently noticed" because I have already printed two models at 1unit = 1inch... both uploaded and printed fine... but now if I export and upload at that setting the obj or stl will fail nine times out of ten. I was pulling my hair out for a week or so trying to figure out the problem, seems obvious now.
Note to shapewyas: It might be wise to mention 3dsmax unit setup settings in the shapeways tutorials for 3ds users.... I didn't anything about that when looking ( http://www.shapeways.com/tutorials/3d_modeling_in_3d_studio_ max_for_shapeways)?
best
-John
www.jchalfant.com/web
Read Message
Previous Topic:I think I Meshed this up.
Next Topic:RHINO user with stl / meshing questions
Goto Forum:
   Go
Current Time: Fri May 24 09:19:10 UTC 2013
