Home » Community » 3D modeler needed » Modeler needed for 35mm dia pendant
Modeler needed for 35mm dia pendant [message #52759] Fri, 17 August 2012 13:40 UTC
avatar mtnman  is currently offline mtnman
I am new to this site and would like to turn a 2D jpg into a 3D pendant (imagine that). Very Happy
Diameter should be around 35mm. The thickness would be about the size of two stacked coins. The Mayan calendar piece thickness would about 1/8" and raised above the lower level sun rays.
Original Design Mock-up
index.php?t=getfile&id=19722&private=0
Black and white versions I've tried using here (I have one model based on the last image below)
http://i243.photobucket.com/albums/ff254/Audixium/Pendant/sol_medallion6.jpg
http://i243.photobucket.com/albums/ff254/Audixium/Pendant/sol_medallion5.jpg
http://i243.photobucket.com/albums/ff254/Audixium/Pendant/sol_medallion2.jpg
Alternative approach (no Mayan 3D print, I would secure a mayan calendar coin to inset into the piece)
http://i243.photobucket.com/albums/ff254/Audixium/Pendant/sol_medallion4.jpg
Material (metals)
Ideally this would be two tone - the sun rays silver, the Mayan calendar gold, and the rim between the two bronze.
Let me know if you would like more info or another image. Thanks!
Read Message
Previous Topic:Modeler
Next Topic:Cat model
Goto Forum:
   Go
Current Time: Sun May 19 13:51:21 UTC 2013
