3D View
3D View [message #55262] Fri, 12 October 2012 16:55 UTC Go to previous message
avatar tomrust  is currently offline tomrust
I edited a version of 3DNP and changed the autorotate function to cycle through the entire list of images, first forward, then backward.
Using the full set of images generated by the Blender script (252 images), the view does 360 rotations but also tilts up and down so you can see the entire model.
There are three files used, 3DNP_config.js, 3DNP.css and blend3dall.html. I put the html file in the same directory as the folder named images which holds all the image files. The .js & css file I keep two levels up - its shared.
This way I can have multiple animation files on a page.
You can see the results at www.custompowersolar.com
Is there a way I can also add these images in place of the 3Dview on my Shapeways Shop?
Read Message
Read Message
Previous Topic:Full Color Sandstone upload Fail
Next Topic:How often do you do a FUD Print? Do you combine S&H, when possible, with follow-up Orders?
Goto Forum:
   Go
