"Transparent" object
"Transparent" object [message #54570] Thu, 27 September 2012 19:38 UTC Go to previous message
avatar pompopom  is currently offline pompopom
Hi everyone,
Need some advice on what material to use for the red colored bowl in a sanctuary lamp (as you can find in churches)
The lamp in our local church has returned from conservation-restoration. Now the historic-preservation organisation, urges us to no longer use the classic-red-glass-bowl-with-candle, but instead use a lamp/led device. This is to prevent smoke from the candle damaging the silver artifact again.
Hence the question: What 's the best material to use for this? Preferably it's red, so full color sandstone, but the FCS can hardly be called transparent... Translucent would do IF by some kind of polishing I could get it to have a 'shiny' look. Is this possible with full color sandstone?
If FCS is an option: How thin do need to design the object to make it transparent/translucent (I agree that this would also depend on the power of the light within the bowl, but let's say for a classic 45W-60W light bulb...) I repeat: it will be a LED device but it can have enough light power.
Any other ideas? Or do I need to go look for a plexi or polycarbonate solution?
Thx for help, advice and time
Koen
The path of excess leads to the tower of wisdom (W. Blake)
Read Message
Read Message
Read Message
Previous Topic:ss moving parts tolerances?
Next Topic:Sealing swp?
Goto Forum:
   Go
