Creating Cavities in Human forms
Creating Cavities in Human forms [message #50141] Thu, 21 June 2012 07:07 UTC Go to next message
avatar rkapuaala  is currently offline rkapuaala
Currently the only way I have to make a cavity in one of my sculpts is to:
1. Edit the sculpt in Meshmixer by creating a negative extrusion from the bottom of the sculpt and then one on the top.
2. Select the bottom of the extrusions and then soft boundaries
3. Bridge and handle.
Then I take the sculpt back into sculptris and slowly create the limbs from that armature and sculpt out the inside. It is a long process more often ending in failture than success.
Worse case scenerio all my apps crash and I start back from my last save. Best case is I get some very thin walls and then have to go back into Meshmixer cut the cavity out like in the attached picture, save the outside mesh, save the cavity and then append one to the other and make slow painful corrections in mesh mixer.
index.php?t=getfile&id=17760&private=0
The teaser is that I have Hexigon, which will make thicknesses, but really can't handle the complex surfaces of my sculpt.
Does anyone know of an inexpensive application that will create a uniform void in a sculpt that doesn't cost an arm and a leg? Don't say solid works, cause I can't afford it.
If you know how to do it in wings 3D, Blender, Hexigon or Carrara then please share those steps with me.
I will appreciate any and all tips.
  • Attachment: cavity.jpg
    (Size: 29.20KB, Downloaded 206 time(s))
Re: Creating Cavities in Human forms [message #50144 is a reply to message #50141 ] Thu, 21 June 2012 10:25 UTC Go to previous messageGo to next message
MeshLab Smile
See http://www.shapeways.com/forum/index.php?t=rview&th=9324 &goto=47799#msg_47799 and start at step 4.
Re: Creating Cavities in Human forms [message #50153 is a reply to message #50144 ] Thu, 21 June 2012 17:27 UTC Go to previous messageGo to next message
stop4stuff wrote on Thu, 21 June 2012 10:25
MeshLab Smile
Brah! that was so easy, I feel stupid I had to ask Embarassed
Here is a pic of a head I did and it took me all of two minutes.
index.php?t=getfile&id=17769&private=0
I've hallowed out a couple of other heads and they have taken me days to get this fine.
Thanks you very much.
Re: Creating Cavities in Human forms [message #50168 is a reply to message #50153 ] Thu, 21 June 2012 22:01 UTC Go to previous message
No worries, something I learned from here on the forums, pass it forward if you can.
Previous Topic:New Metal Options?
Next Topic:[Resolved] Photos of a Shapeways box please?
