| Making a hole in Meshlab [message #50030] Tue, 19 June 2012 17:17 UTC |
I hope this is the right place to put this question out there.
I made a sculpture in Scuptris then Imported it into MeshLab to paint and export as .WRL. When I uploaded the sculpture it came out to be around $80!
I go to looking into the pricing and found that if I make it hallow that will help.
So here's my dilemma. I really don't want to have to repaint it all over again, but I don't know how to make a hole in the top of it in MeshLab. So if you can tell me how to accomplish this I would GREATLY appreciate it!
Thanks for your time, ASC
| Re: Making a hole in Meshlab [message #50037 is a reply to message #50030 ] Tue, 19 June 2012 17:52 UTC |
Someone more MeshLab knowledgeable than me might be able to post a MeshLab method for incoporating a hole, however as far as I know MeshLab is software for manipulating a mesh rather than a full-on editor. To add a hole to make the outside skin and inside skin into a hollow watertight model, you need to save the meshes from MeshLab and then use different software to put the hole in, either as a boolean or direct mesh editing.
| Re: Making a hole in Meshlab [message #50053 is a reply to message #50037 ] Tue, 19 June 2012 21:26 UTC |
Thanks stop4stuff. I was afraid of that. (sigh) Oh well I guess I'll just repaint it.
Thanks again! ~ASC
| Re: Making a hole in Meshlab [message #50102 is a reply to message #50030 ] Wed, 20 June 2012 12:56 UTC |
What you could do before painting (I know a little late for that this time) export to Blender, make it hollow, and either paint in Blender or export back to sculptris to paint. Which ever you prefer.
| Re: Making a hole in Meshlab [message #50112 is a reply to message #50102 ] Wed, 20 June 2012 16:23 UTC |
You're not too late, and thank you!
Blender and I haven't exactly gotten a long yet. LOL. Could you give me instructions on how to make it hallow?
ASCPhotos&Designs
| Re: Making a hole in Meshlab [message #50607 is a reply to message #50030 ] Fri, 29 June 2012 17:18 UTC |
To make a hole in blender to join the exterior and interior wall, select you object. Add another object(in this case I used a cylinder).
The connector between the outer and inner wall can be as tiny as you want. Its not a to drain unused material, it just alerts the 3D printer walls are there.
Do some scaling on the cylinder, make it long enough to intersect the two walls.Place it where you want the hole to be.
In edit mode, select all on the target object, change quads to tris(Cntrl T). Repeat for the hole maker(skinny cylinder). When you use the boolean modifier, it loves tris, less hassle for the computer.
Now select the target object, open up the boolean modifier,(select from modifier menu),
Select difference. Under object on that menu, click on the cube icon, select the name of the hole maker. Apply. You should now have both the outer wall and inner wall connected by a open ended cylinder, thus a hole.
Netfabb basic is good to check that the object is manifold, plus a volume measurement.
Blender versions 2.5 thru 2.63 have a modifier called solidify, where you can set exactly the thickness of the wall.(NICEY!) plus blender can be asked to search for non manifold meshes.
Any help you need with blender, go to # Blender channel on Freenode.net.
| Re: Making a hole in Meshlab [message #50610 is a reply to message #50607 ] Fri, 29 June 2012 17:29 UTC |
| Fredd wrote on Fri, 29 June 2012 17:18 | To make a hole in blender to join the exterior and interior wall, select you object. Add another object(in this case I used a cylinder).
I never did all that, I just deleted the some faces and used the solidify modifier you speak of to make my items.
