| Removing Paint [message #49742] Tue, 12 June 2012 15:08 UTC |
Been working on painting some items recently acquired in WSF. Sprayed them with a quick coat of white primer and started painting, but am very disappointed with my original choice of color. Any recommendations for removing paint?
I normally use Simple Green, is this safe to use on WSF?
| Re: Removing Paint [message #49868 is a reply to message #49742 ] Fri, 15 June 2012 10:48 UTC |
What's Simple Green and what kind of paint have you used? WSF is Nylon-12 if that helps hunting down any answers for reactions.
| Re: Removing Paint [message #49872 is a reply to message #49868 ] Fri, 15 June 2012 14:24 UTC |
Paints... a quick spray with Krylon primer, then common acrylic paints.
Simple Green... http://www.simplegreen.com/
It's a common cleaner. I've used it before on metal and resin castings for paint removal -- usually just needs to let it soak for a couple of days.
Active ingredients per their MSDS sheet:
Water
2-butoxyethanol
Ethoxylated Alchohol
Tetrapotassium Pyrophosphate
Sodium Citrate
| Re: Removing Paint [message #49873 is a reply to message #49872 ] Fri, 15 June 2012 14:34 UTC |
Nail varnish remover and a cotton swab should be just fine for removing acrylic paint without worry of effecting the WSF.
