Home » Community » 3D modeler needed » 14mm x 1.0 Left hand and Right hand Threads
14mm x 1.0 Left hand and Right hand Threads [message #49496] Wed, 06 June 2012 22:57 UTC Go to next message
avatar Dayton  is currently offline Dayton
I'm making a couple parts for my airsoft stuff, and I need 2 sets of female threads (Like a Nut) that I can use to incorporate into my model. I'm not that experienced at modeling, and I'm using Google Sketch-up (Free).
What I need is a female thread, size 14mm x 1.0 CCW.
And one in CW.
Needs to be 20mm long.
So, basically just a threaded tube (threads on the inside) but they have to be 14 mm x 1.0 thread size, and the outside diameter of the tube anywhere between 18 - 20 mm. (O.D. size not critical)
And I would need to be able to import it into Google Sketch-up.
My import options are:
.skp
.3ds
.dem
.ddf
.kms
.dae
Any help here is greatly appreciated.
Re: 14mm x 1.0 Left hand and Right hand Threads [message #49511 is a reply to message #49496 ] Thu, 07 June 2012 09:50 UTC Go to previous messageGo to next message
avatar Matthijs1992  is currently offline Matthijs1992
check this video Cool
http://www.youtube.com/watch?v=MKrWDNDd62c
kind regards Matthijs
Re: 14mm x 1.0 Left hand and Right hand Threads [message #49537 is a reply to message #49511 ] Fri, 08 June 2012 00:26 UTC Go to previous messageGo to next message
Is this the profile what you want? This is with a .1mm tolerance.
index.php?t=getfile&id=17490&private=0
jacantdesign@gmail.com
Re: 14mm x 1.0 Left hand and Right hand Threads [message #49538 is a reply to message #49496 ] Fri, 08 June 2012 00:53 UTC Go to previous messageGo to next message
Yup, that's it.
I think I can do it using the video that Matthijs posted.
Re: 14mm x 1.0 Left hand and Right hand Threads [message #49539 is a reply to message #49538 ] Fri, 08 June 2012 01:13 UTC Go to previous message
Thanks for the help everybody. I was able to do it with the plugin and video linked earlier.
That plugin/process doesn't create a perfect thread, but it's close enough for plastic. Smile
Previous Topic:Gaming Mini
Next Topic:Need simple 3D shape
