| Creator fails to launch with Socket error on Ubuntu 9.04 [message #4547] Fri, 22 May 2009 09:35 UTC |
On Ubuntu 9.04 with the latest Java it fails loading the app with a error
java.net.maleformedURLException unknown protocol:socket
| Re: Creator fails to launch with Socket error on Ubuntu 9.04 [message #4602 is a reply to message #4547 ] Mon, 25 May 2009 09:02 UTC |
Would you please be so kind to let us know what java version you are are using?
To my knowledge Sun java does work, however openjdk sometimes has problems indeed.
Thanks, kind regards, Arno
| Re: Creator fails to launch with Socket error on Ubuntu 9.04 [message #4640 is a reply to message #4602 ] Wed, 27 May 2009 09:49 UTC |
Java(TM) SE Runtime Environment (build 1.6.0_13-b03)
Java HotSpot(TM) Server VM (build 11.3-b02, mixed mode)
on Ubuntu 9.04
I suspect: I'm using the new plug-in that might be the issue. Also network latency is *way* higher from Asia than other locations.
| Re: Creator fails to launch with Socket error on Ubuntu 9.04 [message #4642 is a reply to message #4640 ] Wed, 27 May 2009 12:11 UTC |
Thanks for the followup. I have relayed the information to our developers. I hope to give you an update soon.
Sorry for the inconvenience
