Home » Support » 3D Design » Tips on Hollowing High/Z Resolution Meshes
Tips on Hollowing High/Z Resolution Meshes [message #4501] Tue, 19 May 2009 11:34 UTC Go to next message
avatar akeno  is currently offline akeno
Hey guys.
So I'm one of "those guys", aka ZBrushers (I'm not alone here I know that!? Smile) and I was wondering if anyone had any tips on hollowing out a high resolution mesh to reduce cost size. This is fairly easy to do with low resolution ones, but the higher one because of the face count become a real pain and my system starts to freeze and isn't able to handle it.
Is there a way to do this in ZBrush easily after the mesh is finished? I use Maya so it's really resource dependent on high messes and will probably freeze if I attempt most of mine. Cheers!
Re: Tips on Hollowing High/Z Resolution Meshes [message #4513 is a reply to message #4501 ] Tue, 19 May 2009 21:29 UTC Go to previous message
avatar daddymack  is currently offline daddymack
Hi again akeno, there is a way to do this in Zbrush but it's fiddly
Basically you mask the whole mesh and then extract it with a very thin thickness
Hide the outer mesh and using tools>deformation>inflate 'push' the mesh inwards
You'll need to smooth parts out and do some cleanup etc it makes it easier to see what you're doing if you hit tools>display settings>double
basically unhide the outer shell and you're left with a hollowed tool;)
Otherwise you can 'push' a low res version in maya with inverted normals inside the high res exterior to create the same result but with less polys
Good luck
R
Previous Topic:inverted normals in rhino
Next Topic:inverted normals in rhino
