How to produce many small identical parts - high cost?
How to produce many small identical parts - high cost? [message #48780] Tue, 22 May 2012 23:04 UTC Go to next message
avatar nickdk  is currently offline nickdk
hello everyone Smile
I'm making a modular system that will consist of a lot of small identical parts (like 500) connected by some connector parts. When I upload one of these small parts it gets extremely expensive for each copy. What could i do to include many parts in 1 print job - the price i get doesn't reflect the used cm3 at all, i think it's due to startup cost being added to every part? would i have to connect the parts by a thin line to make the 3d printer create them all at once and then manually separate them later?
Re: How to produce many small identical parts - high cost? [message #48782 is a reply to message #48780 ] Tue, 22 May 2012 23:18 UTC Go to previous messageGo to next message
I just realized that I can have multiple separate non touching copies inside a single upload job file - DOH
I guess this is the way to handle small identical parts?
I always thought that i had to create 1 job for every 1 part :S Shocked
Re: How to produce many small identical parts - high cost? [message #48787 is a reply to message #48782 ] Wed, 23 May 2012 02:40 UTC Go to previous messageGo to next message
You can do that, but you probably shouldn't. Lots of small items would increase the effort required by Shapeways to gather all of your objects, making the handling cost much higher than it should be.
The likely suggestion is to link your models together using sprues of some sort, like the pieces in a store-bought plastic model airplane. Alternatively (I don't know this for sure), a mesh cage to hold all the objects might be doable as well. I'm hoping that someone with more experience with such things will chime in here. I just wanted to encourage printing, but discourage behaviors that would harm our beloved Shapeways.
Oh, and welcome to the community. Very Happy If you give an idea of the scale and quantity of your parts, that might help folks guide you towards a good solution.
Re: How to produce many small identical parts - high cost? [message #48788 is a reply to message #48787 ] Wed, 23 May 2012 05:16 UTC Go to previous messageGo to next message
The question is.. HOW small? If the items are smaller than 1cm3 cubes, then they are extremely labor intensive to remove from the printer.
Shapeways current rules allow a number of discrete shells. If designers start abusing that with large numbers of independent parts, then they will be forced to either reject the models, or go UP in the 'setup fee', which none of us would want.
Keep in mind that models must be picked up by hand (fingers) and placed into the baggies... If they have to repeat that 500 times per file, it's going to drive up their costs.
Use the sprues or the bounding box concept and you should be fine..
Here's one example: http://shpws.me/3XYE
The items here are about 2mm in diameter, and 3mm tall.. just imagine trying to retrieve all 200 of those out of the printer if they were separate objects.
Re: How to produce many small identical parts - high cost? [message #48793 is a reply to message #48788 ] Wed, 23 May 2012 09:33 UTC Go to previous messageGo to next message
the parts are 'beams' 0.8x1.6x25mm - i think the parts will be quite fragile so i'm not too happy intersecting them.
Re: How to produce many small identical parts - high cost? [message #48798 is a reply to message #48793 ] Wed, 23 May 2012 10:14 UTC Go to previous messageGo to next message
You could put the beams loose in a box - 500 of the beams you describe comes in at 16cc, ($23.90) add the volume of the box and the total price is much less than 500 individual models ($1.54 each)
Re: How to produce many small identical parts - high cost? [message #48843 is a reply to message #48780 ] Thu, 24 May 2012 11:18 UTC Go to previous messageGo to next message
avatar Tbmod  is currently offline Tbmod
Problem with that is the box needs to be an open mesh work one so Shapeways can clean the print.
Something 0.8 x 1.6mm is going to fall out of any mesh big enough to let them clean the contents.
Tom
Re: How to produce many small identical parts - high cost? [message #48844 is a reply to message #48843 ] Thu, 24 May 2012 11:34 UTC Go to previous messageGo to next message
Think outside the box and a solution becomes very clear Rolling Eyes -
The box does not need to be a mesh structure.
The box can have closed ends and partial closed sides that overlap the ends of the bars (allowing for clearance spacing)
The box can have a central pillar in the open sides.
Just one kind of box that could work Wink
Re: How to produce many small identical parts - high cost? [message #48858 is a reply to message #48844 ] Thu, 24 May 2012 16:55 UTC Go to previous messageGo to next message
avatar SirThankzALot  is currently offline SirThankzALot
If too many tiny pieces are a problem for Shapeways, you could create a scaffolding or somehting that can be snapped or sanded off, enough for the piece to successfully print, then go to a hobby store and make a mold and cast your own copies.
Re: How to produce many small identical parts - high cost? [message #48869 is a reply to message #48844 ] Thu, 24 May 2012 19:22 UTC Go to previous messageGo to next message
stop4stuff wrote on Thu, 24 May 2012 11:34
Could someone show a drawing of such a box? I'm a bit confused about the box method - I don't want to complicate things too much :S
Re: How to produce many small identical parts - high cost? [message #48871 is a reply to message #48869 ] Thu, 24 May 2012 19:33 UTC Go to previous messageGo to next message
For sure, give me a day and as long as no paid work comes in, I'll have a box model that can work by this time tomorrow - can you PM me with the base model you need multiples of?
Re: How to produce many small identical parts - high cost? [message #48872 is a reply to message #48871 ] Thu, 24 May 2012 19:37 UTC Go to previous messageGo to next message
stop4stuff wrote on Thu, 24 May 2012 19:33
Paul that's very nice of you, the base part is not in place yet, I was just asking for a quick sketch or so to show the box idea Smile I can model it myself.
Re: How to produce many small identical parts - high cost? [message #48874 is a reply to message #48872 ] Thu, 24 May 2012 19:55 UTC Go to previous messageGo to next message
no worries Smile
Sketching with imagination here (modelling would take less time than pen & paper)
grab a shoe box, fill it with twigs just a little shorter than the box length - fill the box but allow clearance spacing between the twigs.
Now grab a sharp knife and cut out two windows that are about 1/3 the length of the sides and top of the box, space the windows evenly so that there is an upright between the pair of windows on each side - do not cut windows on the ends.
Does that do it?
Re: How to produce many small identical parts - high cost? [message #48881 is a reply to message #48874 ] Thu, 24 May 2012 23:15 UTC Go to previous messageGo to next message
Here's one suggestion.
index.php?t=getfile&id=17158&private=0
In this design, the "cap" on each end needs to be enough to keep the items from falling out. Depending upon how many items you are trying to print at once, you may need internal cross-braces to keep the items "standing up".
  • Attachment: Box.jpg
    (Size: 24.25KB, Downloaded 164 time(s))
Re: How to produce many small identical parts - high cost? [message #48882 is a reply to message #48881 ] Thu, 24 May 2012 23:22 UTC Go to previous message
thank you very much, i understand the concept now! Smile
Previous Topic:Modeling tolerances to get 'grip' FUD and White, Strong & Flexible?
Next Topic:How to make a model car replica? Please help!
