| I can't believe it's not rubber.... [message #48608] Thu, 17 May 2012 19:58 UTC |
http://www.shapeways.com/blog/archives/1375-Introducing-3D-P rinted-Black-Elasto-Plastic-I-Cant-Believe-Its-Not-Rubber.ht ml
It squishes, it stretches, and erases pencil drawings.... I'm happy to announce that starting today, Shapeways will enable you to print in our first stretchy squishy material!
Check out the above link for more details and some design inspirations.
The rules are flexible and subject to change, since this is an experimental material. Don't be afraid to stretch your imagination! </endbadpuns>
Enjoy!
Nancy
[Updated on: Thu, 17 May 2012 19:59 UTC]
Product Manager
Twitter: @nliang
| Re: I can't believe it's not rubber.... [message #48635 is a reply to message #48608 ] Fri, 18 May 2012 09:33 UTC |
Is Bowie printable in Black Elasto ?
( Let's make that bunny dancing like this "MyKeepon" thing. )
| Re: I can't believe it's not rubber.... [message #48653 is a reply to message #48635 ] Fri, 18 May 2012 18:26 UTC |
Sure is! Though, there's a bunny in 1.0mm and one in 2.0mm, the minimum wall thickness for this is 1.5mm, so I'd recommend using the 2.0mm version--though it will be a bit stiffer (maybe see if the designer can design a version that's 1.5mm thick?)
Product Manager
Twitter: @nliang
| Re: I can't believe it's not rubber.... [message #48764 is a reply to message #48635 ] Tue, 22 May 2012 17:27 UTC |
I didn't quite catch the connotation of "this my keepon thing"
And, BTW, where are the winners of the FlexTest contest posted?
[Updated on: Tue, 22 May 2012 17:31 UTC] cascador
| Re: I can't believe it's not rubber.... [message #49471 is a reply to message #48608 ] Wed, 06 June 2012 14:10 UTC |
I have made the new flexible material available as a option.
Rob
| Re: I can't believe it's not rubber.... [message #49634 is a reply to message #48608 ] Sun, 10 June 2012 18:34 UTC |
I am excited about designing with this great new material. I have one request, and I'd like to hear what others think.
It would be great if the material was light gray in color. That would make the grainy appearance of the material less visible, and would prevent it from looking dirty when used for functional items like phone cases (one of the main problems with WSF material). It would also make it clear, in photos of multi-part designs, which material is being used where. Finally, light gray would photograph very well.
| Re: I can't believe it's not rubber.... [message #49669 is a reply to message #49634 ] Mon, 11 June 2012 16:08 UTC |
Hi Aaron,
The color of the flex material is actually part of its structure, so for now, we can't change the color as it is a coating integral to its properties.
So there is no option to change the color in Flex, sorry about that!
For now, if you are seeking color options you could use WSF in black red or purple, full color sandstone or ceramics.
Best,
Natalia
Community Manager | Shapeways
| Re: I can't believe it's not rubber.... [message #49683 is a reply to message #49682 ] Mon, 11 June 2012 19:16 UTC |
Hey Aaron!
Natalia is right in that the color adds structural strength to the product, but you are also right that there are other color infiltrants we can use.. possibly even gray.
Currently, though, we are learning a lot from this material but more colors is definitely on the list if we get some other issues solved first. Right now, the design rules are pretty conservative and we are looking at a bunch of designs incoming that unfortunately are too thin to be printed. We're trying to brainstorm some better way to communicate design rules or draw attention to these things so models that gets submitted are printable models.
Open to suggestions!
(then we can get on to more colors)
Product Manager
Twitter: @nliang
| Re: I can't believe it's not rubber.... [message #49699 is a reply to message #48608 ] Mon, 11 June 2012 20:02 UTC |
Thanks, Nancy.
I spoke with you and the whole team about this in January, in great detail. That is an awful long time to be brainstorming. I can help. Send me an email.
| Re: I can't believe it's not rubber.... [message #49732 is a reply to message #49677 ] Tue, 12 June 2012 10:32 UTC |
| aeron203 wrote on Mon, 11 June 2012 17:50 |
I assume Shapeways is using 3DSystems Duraform Flex material, infiltrated with Flex Seal 2-part urethane. While it is true that Flex Seal is only available in Black, Red, Yellow, Blue, and Natural White, the spec sheet says they can be mixed to create custom colors. Take a look at the brochure here:
http://www.rpc.msoe.edu/datasheets/sls/Duraform_Flex.pdf
AFAIK it's probably ALM's TPE-210 S. Though they're very similar.
| Re: I can't believe it's not rubber.... [message #49798 is a reply to message #48608 ] Thu, 14 June 2012 10:08 UTC |
Has anybody tried painting this material yet? What is the best paint to use?
