Home » Community » General Discussion » I can't believe it's not rubber....
I can't believe it's not rubber.... [message #48608] Thu, 17 May 2012 19:58 UTC Go to next message
avatar nancyliang  is currently offline nancyliang
http://www.shapeways.com/blog/uploads/squishyanimation.gif
http://www.shapeways.com/blog/archives/1375-Introducing-3D-P rinted-Black-Elasto-Plastic-I-Cant-Believe-Its-Not-Rubber.ht ml
It squishes, it stretches, and erases pencil drawings.... I'm happy to announce that starting today, Shapeways will enable you to print in our first stretchy squishy material!
Check out the above link for more details and some design inspirations.
The rules are flexible and subject to change, since this is an experimental material. Don't be afraid to stretch your imagination! </endbadpuns>
Enjoy!
Nancy
[Updated on: Thu, 17 May 2012 19:59 UTC]
Product Manager
Twitter: @nliang
Re: I can't believe it's not rubber.... [message #48635 is a reply to message #48608 ] Fri, 18 May 2012 09:33 UTC Go to previous messageGo to next message
Is Bowie printable in Black Elasto ?
( Let's make that bunny dancing like this "MyKeepon" thing. Very Happy )
Re: I can't believe it's not rubber.... [message #48653 is a reply to message #48635 ] Fri, 18 May 2012 18:26 UTC Go to previous messageGo to next message
Sure is! Though, there's a bunny in 1.0mm and one in 2.0mm, the minimum wall thickness for this is 1.5mm, so I'd recommend using the 2.0mm version--though it will be a bit stiffer (maybe see if the designer can design a version that's 1.5mm thick?)
Product Manager
Twitter: @nliang
Re: I can't believe it's not rubber.... [message #48654 is a reply to message #48635 ] Fri, 18 May 2012 18:29 UTC Go to previous messageGo to next message
Here's the link: http://www.shapeways.com/model/97938/bowie-the-bunny-2mm-thi ck.html
(You might have to ping the designer and ask to enable the Elastic material first)
Check out some of the other items.. the bunny isn't the only cute thing in the shop!
Product Manager
Twitter: @nliang
Re: I can't believe it's not rubber.... [message #48764 is a reply to message #48635 ] Tue, 22 May 2012 17:27 UTC Go to previous messageGo to next message
avatar opresco  is currently offline opresco
I didn't quite catch the connotation of "this my keepon thing" Very Happy
And, BTW, where are the winners of the FlexTest contest posted?
[Updated on: Tue, 22 May 2012 17:31 UTC]
cascador
Re: I can't believe it's not rubber.... [message #48765 is a reply to message #48608 ] Tue, 22 May 2012 17:31 UTC Go to previous messageGo to next message
Flex test contest!
Re: I can't believe it's not rubber.... [message #49471 is a reply to message #48608 ] Wed, 06 June 2012 14:10 UTC Go to previous messageGo to next message
avatar BAROBA  is currently offline BAROBA
I have made the new flexible material available as a option.
Rob
Re: I can't believe it's not rubber.... [message #49634 is a reply to message #48608 ] Sun, 10 June 2012 18:34 UTC Go to previous messageGo to next message
I am excited about designing with this great new material. I have one request, and I'd like to hear what others think.
It would be great if the material was light gray in color. That would make the grainy appearance of the material less visible, and would prevent it from looking dirty when used for functional items like phone cases (one of the main problems with WSF material). It would also make it clear, in photos of multi-part designs, which material is being used where. Finally, light gray would photograph very well.
Re: I can't believe it's not rubber.... [message #49669 is a reply to message #49634 ] Mon, 11 June 2012 16:08 UTC Go to previous messageGo to next message
Hi Aaron,
The color of the flex material is actually part of its structure, so for now, we can't change the color as it is a coating integral to its properties.
So there is no option to change the color in Flex, sorry about that!
For now, if you are seeking color options you could use WSF in black red or purple, full color sandstone or ceramics.
Best,
Natalia
Shapeways Community Manager
Re: I can't believe it's not rubber.... [message #49677 is a reply to message #49669 ] Mon, 11 June 2012 17:50 UTC Go to previous messageGo to next message
Thank you for your reply Natalia.
It would be great if Nancy could interact directly since this is her area of expertise.
I assume Shapeways is using 3DSystems Duraform Flex material, infiltrated with Flex Seal 2-part urethane. While it is true that Flex Seal is only available in Black, Red, Yellow, Blue, and Natural White, the spec sheet says they can be mixed to create custom colors. Take a look at the brochure here:
http://www.rpc.msoe.edu/datasheets/sls/Duraform_Flex.pdf
Just to make things super easy for you all I've attached the brochure and a embedded a screenshot with the relevant information.
http://i46.tinypic.com/330wsxj.jpg
The material comes in 1kg cans, and I'm sure Shapeways will go through a lot of it if they offer it in a useful color. Simply mixing 3 cans of white with each can of black would give you a material that is actually useful for end-use products.
Just my two cents as one of your customers. Smile
Re: I can't believe it's not rubber.... [message #49680 is a reply to message #48608 ] Mon, 11 June 2012 18:01 UTC Go to previous messageGo to next message
As always, if you want it, add it to feedback and get everyone that feels the same to vote it up. http://feedback.shapeways.com/forums/111989-shapeways-feedba ck
Re: I can't believe it's not rubber.... [message #49682 is a reply to message #49680 ] Mon, 11 June 2012 18:45 UTC Go to previous messageGo to next message
Good call, Mike. I added to the feedback section here:
http://feedback.shapeways.com/forums/111989-shapeways-feedba ck/suggestions/2918769-appropriate-color-for-elasto-material
Re: I can't believe it's not rubber.... [message #49683 is a reply to message #49682 ] Mon, 11 June 2012 19:16 UTC Go to previous messageGo to next message
Hey Aaron!
Natalia is right in that the color adds structural strength to the product, but you are also right that there are other color infiltrants we can use.. possibly even gray.
Currently, though, we are learning a lot from this material but more colors is definitely on the list if we get some other issues solved first. Right now, the design rules are pretty conservative and we are looking at a bunch of designs incoming that unfortunately are too thin to be printed. We're trying to brainstorm some better way to communicate design rules or draw attention to these things so models that gets submitted are printable models.
Open to suggestions!
(then we can get on to more colors)
Product Manager
Twitter: @nliang
Re: I can't believe it's not rubber.... [message #49699 is a reply to message #48608 ] Mon, 11 June 2012 20:02 UTC Go to previous messageGo to next message
Thanks, Nancy.
I spoke with you and the whole team about this in January, in great detail. That is an awful long time to be brainstorming. I can help. Send me an email.
Re: I can't believe it's not rubber.... [message #49732 is a reply to message #49677 ] Tue, 12 June 2012 10:32 UTC Go to previous messageGo to next message
aeron203 wrote on Mon, 11 June 2012 17:50
AFAIK it's probably ALM's TPE-210 S. Though they're very similar.
Re: I can't believe it's not rubber.... [message #49798 is a reply to message #48608 ] Thu, 14 June 2012 10:08 UTC Go to previous messageGo to next message
avatar SDabbs  is currently offline SDabbs
Has anybody tried painting this material yet? What is the best paint to use?
Re: I can't believe it's not rubber.... [message #98397 is a reply to message #49677 ] Thu, 11 September 2014 07:27 UTC Go to previous message
avatar hmbpm  is currently offline hmbpm
Does anyone know how much the DuraDorm Flex Seal infiltrant costs and where or if I can buy it? I searched all over the internet but couldn't find anything...
Previous Topic:Promotion of your Shapeways shop
Next Topic:I want to get Photo of human figures from shapeway 3 d printed
