magnetic objects
magnetic objects [message #48526] Wed, 16 May 2012 12:53 UTC Go to next message
avatar kiorodesign  is currently offline kiorodesign
The 3D metal printing process seems to produce magnetic objects. Watch the video...
http://www.youtube.com/watch?v=WP8mNJBE0UQ
KIORO'design Team Ciro & Giovanna
Re: magnetic objects [message #48529 is a reply to message #48526 ] Wed, 16 May 2012 13:53 UTC Go to previous messageGo to next message
The SS component of the print media is alloy 420 stainless, which unlike 300 series alloys can be magnetized. Printed parts are processed in controlled atmosphere electric furnaces.The heating coil arrangement in these furnaces is circular array. Like a coil surrounding the batch of parts during operation. This might be the source of parts becoming magnetic. Usually this is almost in-detectable in a given part. Your video of those "propellers" is quite remarkable actually! Probably some Big Science going on but I sure can't explain it.
-G
Leonardo da Vinci
Re: magnetic objects [message #48530 is a reply to message #48529 ] Wed, 16 May 2012 13:59 UTC Go to previous messageGo to next message
thanks for the very detailed technical explanation...
Ciro
Re: magnetic objects [message #48536 is a reply to message #48530 ] Wed, 16 May 2012 17:14 UTC Go to previous messageGo to next message
Kioro,
Just a guess, probably not the whole story. Most parts do not come out magnetized like your turbine design. This would make a nice science project for some brainiac Very Happy
-G
Leonardo da Vinci
Re: magnetic objects [message #48539 is a reply to message #48526 ] Wed, 16 May 2012 17:59 UTC Go to previous messageGo to next message
Is it that 'Shapeways produce magnetic odjects' or is it that Shapeways produce objects have the properties to infulence the Earth's magnetic field?
Laughing
Re: magnetic objects [message #48542 is a reply to message #48539 ] Wed, 16 May 2012 20:57 UTC Go to previous messageGo to next message
To influence the magnetic field of the EARTH.. you'd need a printer with a slightly larger build volume.
Re: magnetic objects [message #48548 is a reply to message #48526 ] Wed, 16 May 2012 22:21 UTC Go to previous messageGo to next message
avatar tempusr88898_d560e03d74a  is currently offline tempusr88898_d560e03d74a
Wow that video is really cool!
So, is it the turbine shape that made the print come out magnetic?
Will it happen again if you order other print of the same model, or was it a one time fluke?
Re: magnetic objects [message #48549 is a reply to message #48548 ] Wed, 16 May 2012 22:28 UTC Go to previous messageGo to next message
Good question Mary. The phenomena is unintentional, we would probably need and expert in electromagnetics to explain it.
-G
Leonardo da Vinci
Re: magnetic objects [message #48580 is a reply to message #48526 ] Thu, 17 May 2012 12:29 UTC Go to previous messageGo to next message
avatar ggurov  is currently offline ggurov
what would be a case where having an SS part be magnetized, even slightly, be detrimental ? i could see not wanting various pieces be magnetized if you work around computer parts, especially hard drives, but the magnetic field would have to be quite a bit bigger there to do any kind of damage.
Database Architect, DBA, Datacenter guru, infrastructure wizard, none of the above.
Re: magnetic objects [message #48585 is a reply to message #48542 ] Thu, 17 May 2012 12:52 UTC Go to previous messageGo to next message
stonysmith wrote on Wed, 16 May 2012 20:57
Or a man and a wench http://en.wikipedia.org/wiki/Coral_Castle
Back on topic, could it be caused by polishing, sanding of sprues?
Re: magnetic objects [message #48938 is a reply to message #48526 ] Fri, 25 May 2012 18:55 UTC Go to previous messageGo to next message
I have magnetized my stainless steel pieces when polishing them... and part of the process involved using a stainless steel brush in a Dremel...
Glenn
Re: magnetic objects [message #48947 is a reply to message #48938 ] Fri, 25 May 2012 22:22 UTC Go to previous message
Yah that could definitely do it. Even on a piece of plain steel friction can induce magnetic properties. This is very slight but observable. It's generally not a problem and can be reversed with the use of a de-magnetizing tool.
-G
Leonardo da Vinci
Previous Topic:Really cool way to interact with your computer
Next Topic:Material properties - density
