Home » Community » Work in progress » Dice using euro coins
Dice using euro coins [message #47075] Mon, 16 April 2012 18:48 UTC Go to next message
Hi all,
I was considering how to combine my Truncated Sphere Dice with the new flexible squishy material, and I had the idea to make a big die where you could insert a 1 euro coin on each face (not my first design using euro coins).
I begin with 12 faces because this was the number of countries using euro in 2001.
The goal is to have on coin from each country and thus to select a country by throwing the die (perhaps to choose a travel destination Smile ).
Here is what it could look like:
/openfilens/541356/photos/photo82467.jpg
Another version would be based on a simple dodecahedron:
/openfilens/541355/photos/photo82470.jpg
The external holes have a radius 1 mm smaller than the coin (that is a diameter 2 mm smaller) : I hope this will allow to insert the coin but still provide a good grip.
The internal hole are instead 2 mm smaller in radius (4 mm in diameter): the coin is not supposed to go through those ones.
Perhaps I should add some cuts (for instance five) around the external hole to make it easier to insert the coin...
What do you think? Will it be functional? Is it something you would like to have?
[Updated on: Mon, 16 April 2012 18:57 UTC]
Re: Dice using euro coins [message #47076 is a reply to message #47075 ] Mon, 16 April 2012 19:15 UTC Go to previous messageGo to next message
I like it, particularly the first one. But it seems more appropriate to a rigid material, where you could simply epoxy the coins in.
[Updated on: Mon, 16 April 2012 19:16 UTC]
Re: Dice using euro coins [message #47079 is a reply to message #47075 ] Mon, 16 April 2012 19:49 UTC Go to previous messageGo to next message
In my opinion, that won't work.
Try to throw a round manhole cover in the manhole...
Even with the squishy material. At least the last coin will be very problematic, because the other coins make the whole thing very rigid.
Re: Dice using euro coins [message #47134 is a reply to message #47075 ] Wed, 18 April 2012 00:39 UTC Go to previous messageGo to next message
avatar CharGyse  is currently offline CharGyse
I think they'd be able to squeeze in fine without the cuts, since the video of the material showed that it can stretch a little bit if it has to without breaking. When I was thinking about the new material, I was imagining a "canvas" built up of lots of circles like the ones on each of your faces, except I was thinking of inserting various bottle caps.
The only problem I can see with it is coins falling out on impact when it lands - but then again I don't actually know how big or heavy a Euro coin is...
Enjoys spending 98 hours a week learning, making and designing stuff. The picture of me as a kid is... pretty much what you're dealing with.
Re: Dice using euro coins [message #47142 is a reply to message #47134 ] Wed, 18 April 2012 05:40 UTC Go to previous messageGo to next message
Thank you all for your answers.
The reason why I prefer not the glue the coins is that I am a coin collector, so I like the idea to be able to get them back at some point.
It is difficult to know if the coins can be inserted (and removeved) without falling, as long as the model is not prototyped. That's the beauty of 3D printing to be able to do so for (hopefully) a reasonable cost.
There are a lot of parameters that can be tweaked to make it work like the diameter of the external hole, the number of cuts, the shape of the section (squared, rounded) the thickness and so on.
I am afraid I will have to be patient and then give it a try...
Re: Dice using euro coins [message #47247 is a reply to message #47142 ] Fri, 20 April 2012 06:05 UTC Go to previous messageGo to next message
Couldn't you make the hole exactly the right size for the coin, but with a small lip around the edge to hold it in. So the coin is recessed slightly into the die. Something like:
Re: Dice using euro coins [message #47252 is a reply to message #47247 ] Fri, 20 April 2012 09:19 UTC Go to previous messageGo to next message
I think that's what Magic has done, the lip being 1mm in all around, but with another "lip" on the inside of the face being 2mm (presumably to let out material?).
Re: Dice using euro coins [message #47255 is a reply to message #47075 ] Fri, 20 April 2012 10:41 UTC Go to previous messageGo to next message
The die looks very cool indeed.
I don't think you'll have any problems inserting the coins, the last one might be tricky an require the use of a tool to lever the coin in, similar to the way a tyre iron is used get a car or bike tyre over the wheel rim. I don't even think you'd need cuts.
Re: Dice using euro coins [message #47305 is a reply to message #47255 ] Sat, 21 April 2012 10:18 UTC Go to previous messageGo to next message
Thanks again for your feedbacks.
Here is a sliced version of the model to better understand the principle:
http://images.shapeways.com/model/640x476/541356/83125/jpeg
So yes, it is basically how you suggested, Henry and CharGyse.
Stop4Stuff, I like the tyre analogy. I hope it will work this way.
[Updated on: Sat, 21 April 2012 10:20 UTC]
Re: Dice using US quarter [message #48483 is a reply to message #47305 ] Tue, 15 May 2012 21:07 UTC Go to previous message
I did a version for quarters as I know you can find quarters from different states or even commemorative quarters.
I only changed some dimensions of the dodecahedron to match the size of this coin.
Please welcome the DodQuarter:
http://images.shapeways.com/model/picture/640x476_572487_86925_1337272278.jpg
This is the version printed by Shapeways.
[Updated on: Fri, 18 May 2012 16:13 UTC]
Previous Topic:DodBox in Ceramics
Next Topic:Durer Alphabet Project
