Static Image Display
Static Image Display [message #46847] Thu, 12 April 2012 06:50 UTC Go to next message
avatar PlainOrb  is currently offline PlainOrb
Hi, I can't find my last topic regarding image display, so I got this new topic.
Here is an example of static image display:
http://www.behance.net/gallery/3D-Printed-USB-Dust-Cap-Leaf- Style/3544895
and here is how the same images are dynamically displayed on shapeways:
http://www.shapeways.com/model/504592/usb-dust-cap-leaf-styl e.html
You may compare the two display means and see that dynamic display shows an obvious overcompression on images.
I used to be an amateur graphic designer and would suggest using static image display for better image quality.
[Updated on: Thu, 12 April 2012 06:57 UTC]
PLAIN ORB
Re: Static Image Display [message #46866 is a reply to message #46847 ] Thu, 12 April 2012 17:20 UTC Go to previous messageGo to next message
Sorry... I'm still not comprehending what you are suggesting. Most of those images seem to me to be equal in quality/resolution.
Re: Static Image Display [message #46881 is a reply to message #46866 ] Thu, 12 April 2012 18:52 UTC Go to previous messageGo to next message
stonysmith wrote on Thu, 12 April 2012 17:20
I notice the shapeways image is not as crisp. Especially if you look at the leaf itself (open both and switch back and forth) Maybe this is done for load speed? I don't know graphics or coding so I have no idea.
Re: Static Image Display [message #46888 is a reply to message #46881 ] Thu, 12 April 2012 19:59 UTC Go to previous messageGo to next message
Yep, one picture is ten times the size of the other. And if you work out how many photos Shapeways hosts you may get an inkling of how much more bandwidth higher definition images would cost them.
Bill Bedford
Re: Static Image Display [message #46916 is a reply to message #46847 ] Fri, 13 April 2012 07:04 UTC Go to previous message
You may open both links, compare the image with keyboard and compare the words on the keyboard. Keyboard words are clear on Behance.net and blur on Shapeways.com
You may learn more about image over compression at
http://brycetech.daz3d.com/tutor/windows/jpeg_compression.ht ml
Shapeways display images in dynamic means, which usually require Adobe Flash Player for viewing.
Behance display images in static means, which simply list all images one after another and do not require Adobe Flash Player for viewing.
[Updated on: Fri, 13 April 2012 07:09 UTC]
PLAIN ORB
Previous Topic:Mark Up Setting
Next Topic:April Payments
