Home » Support » 3D Design » size problems (STL and WRL exports)
icon5.gif  size problems (STL and WRL exports) [message #4228] Sat, 02 May 2009 18:41 UTC Go to next message
avatar brainbow  is currently offline brainbow
Hello!
really new here!
I'm uploading my first models and it seams that there is a problems with sizing.
My original models (3dsmax8) are in the scale of centimeters and mms, but I'm getting e-mails from Shapeways stating that they are to big.
For example a part that mesures 4 x 2,8 x 1,55 cm when exported, reads as:
58.1 x 108.5 x 154.5 cm (h x w x d).
Does someone had the same problem?
Re: size problems (STL and WRL exports) [message #5092 is a reply to message #4228 ] Thu, 02 July 2009 01:10 UTC Go to previous messageGo to next message
I have the exact same problem, have you found a solution?
Regards, Jack
Re: size problems (STL and WRL exports) [message #5094 is a reply to message #5092 ] Thu, 02 July 2009 07:29 UTC Go to previous messageGo to next message
Hello!
it seems exporting in .DAE and using generic units (not metric) works OK (in 3dstudioMax).
Re: size problems (STL and WRL exports) [message #5271 is a reply to message #5094 ] Thu, 16 July 2009 18:38 UTC Go to previous message
Thank you for the reply, I will try this out Smile
Regards, Jack
Previous Topic:Hair pulling - FIXED
Next Topic:<FIXED> Non-manifold solid?
