Home » Support » Buying »
How is density calculated?
How is density calculated? [message #45897] Sat, 24 March 2012 04:16 UTC Go to next message
avatar jwholper94  is currently offline jwholper94
This may be the wrong board to ask this in, but this seemed like the best fit.
For WSF, there is a discount after 20cc and a density over 10%. I am wondering how shapeways calculates density?
Also, am I interpreting this correctly in that the in order for the discount to be applied, you have to have both the volume and density, not one or the other?
Re: How is density calculated? [message #45900 is a reply to message #45897 ] Sat, 24 March 2012 06:05 UTC Go to previous message
I can't be 100% sure of the actual method Shapeways uses, but Density (should be) equal to Material Volume divided by BoundingBox Volume
Consider this shape:
index.php?t=getfile&id=15519&private=0
Lets say that it's measurements are 5cm*5cm*1cm
Then, the Material used is 4+4+1 = 9cm3, and the Bounding Box is 5x5x1 = 25cm3
That means this shape has a density of 9/25 = 36%
[Updated on: Sat, 24 March 2012 06:06 UTC]
Previous Topic:Import duty
Next Topic:Shipping time and Order
