| Re: Introducing and material question [message #45751 is a reply to message #45749 ] Tue, 20 March 2012 18:56 UTC |
Welcome Menno,
The material is really up to you and what you want from your model. if you want the most detail than FUD is your choice. If you want lower cost, lower detail than maybe one of the other Detail materials or even WSF. If you want to set it on your table as a show piece, maybe ceramic. If you want to wear it around your neck, maybe silver. It's all up to you and what you want to do with the piece. Check all the details for all the materials here
| Re: Introducing and material question [message #45754 is a reply to message #45751 ] Tue, 20 March 2012 19:14 UTC |
@ Youknowwho4eva
Hello and thanx for answer.
So what you mean is that actually I can use any material? There is no difference in what material is best for a curly object like mine or an object with all straight faces?
I myself was indeed thinking of ceramic, also because of my work: making ceramic bone replacement materials for surgery and so on But that FUD (have to see what that means ) also sounds nice.
But got some more info now, thanx
| Re: Introducing and material question [message #45755 is a reply to message #45749 ] Tue, 20 March 2012 19:19 UTC |
for your level of detail on that model, you'd want FUD (frosted ultra detail) unless it's large enough that those details would show in ceramic. You'll need to go through the material page and see the individual levels of detail per material, to see which level of detail best suits you.
| Re: Introducing and material question [message #45758 is a reply to message #45755 ] Tue, 20 March 2012 19:32 UTC |
That material page is indeed handy. FUD indeed sounds great but on the other hand (if this printing works out for my art) I want to be able to make it rather touchable, so people can hold it, rotate it and so one. And that FUD is rather delicate. So maybe WFS is the better option then.
Ah well, no other way to find out to order and see how it turns out
| Re: Introducing and material question [message #45759 is a reply to message #45749 ] Tue, 20 March 2012 19:47 UTC |
WSF is stronger. But with a lot of touching, it's very porous, so it will get dirty. FUD is delicate when thin. As long as the body of your piece is substantial enough, it shouldn't be too delicate.
