Silver printing
Silver printing [message #45131] Fri, 09 March 2012 14:01 UTC Go to next message
avatar moniquehorsman  is currently offline moniquehorsman
I want to print something in silver, so i checked the max measurements and it says: 15x15x3cm(*)
But this (*) says: (*) Dependent on the design, for more information see Silver Design Rules
Silver design rules
The basics...
Wall thickness minimum: .6 mm ---> yes
Detail thickness minimum: .3 mm ---> yes
And no Embossing needed...
So what other factors do I need to be aware of if I want to print in Silver?
Will that mean I am able to print a larger model?
Please help!
thanks!
Smile
Re: Silver printing [message #45133 is a reply to message #45131 ] Fri, 09 March 2012 15:39 UTC Go to previous messageGo to next message
Hi Monique,
No this is the maximum size.
But if you take the maximum size of 15x15x3cm, the model needs to have a thicker wallthickness then the 0.6mm as it will probably be to fragile if you have a long wall of 15cm which is just 0.6mm thick.
Good luck with your design!
Re: Silver printing [message #45140 is a reply to message #45133 ] Fri, 09 March 2012 17:15 UTC Go to previous message
Hi Monique & Jettuh Smile
Even small items in silver sometimes need larger than 0.6mm wall thickness. Rolling Eyes
For a larger-than-printable item, I'd suggest multiple models that would be able to be soldered together - or find a company that will supply the wax models that can be joined together before invstement.
Previous Topic:Ceramics - glaze dimensions?
Next Topic:IPhone case material
