Just an fyi for anyone else looking into tapping holes. The listed tap drill sizes are usually for a 72-75% thread. If you are just attaching parts and not looking for max strength use a larger size tap drill, it will make tapping much easier.
For depth of thread engagement the general rule for max strength is "2*D" @ 72-75% thread( 2 times the diameter of the bolt). After that its diminishing returns.
One of the most important things, especially on the stainless steel, is your choice of lubricant. If its hard and tough, I use "Tap-Magic"--after tapping hundreds of 4-40 threads in stainless nothing else will do!(and I've never had to use a carbide tap)
For the plastics it's dishsoap and water or compressed air.
@GlenG-
I have not had a chance to machine any of the Shapeways SS. Is the base SS alloy a free-machining alloy?
That being said everything that follows is conjecture..
I have to think with all the bronze/brass in the finished product that it must exhibit some free machining properties? And being that it's relatively hard, would a tool geometry similar to one for brass/plastic work better? Perhaps its just not a mat'l. that likes being cut and prefers the "scrape"?
ymmv
hope it helps some
bvr
edits: can't speel
