The model problem of convergence for help
The model problem of convergence for help [message #43922] Mon, 13 February 2012 10:14 UTC Go to next message
avatar idtdi  is currently offline idtdi
Hello, everyone
I do Full Color Sandstone 3Dprint the model is a roadblock consisting of spherical.So I added a box below each point of contact (within the sphere) to increase the minimum thickness of the thin-wall at the point of contact between each roadblock is very small and very dangerous, but the upload repeatedly have been rejected, Rejection reason: bad the geometry, thin walls (below 2mm)
I am confused about how to modify this model?
index.php?t=getfile&id=14582&private=0index.php?t=getfile&id=14581&private=0index.php?t=getfile&id=14580&private=0
  • Attachment: 1.PNG
    (Size: 35.36KB, Downloaded 195 time(s))
  • Attachment: 3.PNG
    (Size: 24.71KB, Downloaded 183 time(s))
  • Attachment: 4.PNG
    (Size: 37.73KB, Downloaded 183 time(s))
Re: The model problem of convergence for help [message #43971 is a reply to message #43922 ] Tue, 14 February 2012 00:38 UTC Go to previous messageGo to next message
It's not obvious what's wrong here. Could you possibly share the 3d model? You can just PM it to me if you'd rather keep it private.
Re: The model problem of convergence for help [message #43985 is a reply to message #43971 ] Tue, 14 February 2012 07:01 UTC Go to previous messageGo to next message
Sorry I was a novice understand the rules forget to upload the model attachments
  • Attachment: 3d model.zip
    (Size: 718.69KB, Downloaded 54 time(s))
Re: The model problem of convergence for help [message #44009 is a reply to message #43922 ] Tue, 14 February 2012 15:43 UTC Go to previous messageGo to next message
Have you tried uploading as a new item, or just as updating an existing item? I saw an issue last week with updating, that you may be running into as well.
Re: The model problem of convergence for help [message #44045 is a reply to message #43922 ] Wed, 15 February 2012 01:56 UTC Go to previous messageGo to next message
The last attachment is a 3dsmax model, and then upload a. Of WRL file with the color map compression package.I hope someone can tell me where the problem is?How can it be solved?Each be returned only wall thickness, so that I was too confused.
http://hotfile.com/dl/142243795/1a0a2fb/01_17.zip.html
Re: The model problem of convergence for help [message #44050 is a reply to message #44045 ] Wed, 15 February 2012 03:51 UTC Go to previous messageGo to next message
Are you getting this "too thin" message after you have ordered your model, or during the initial upload? I don't see anything here that would prevent it from being uploaded correctly.
But.. the problem MIGHT be related to the fact that you've got multiple shells here. Sometimes multiple shells can give false readings when the production team goes to measuring the model for thin walls. You could try to combine the separate shells down into a single shell.
Re: The model problem of convergence for help [message #44058 is a reply to message #44050 ] Wed, 15 February 2012 08:03 UTC Go to previous messageGo to next message
Yes, man.
When I uploaded firstly, it shows "successful" message.
But it kept coming to tell me"faults" later.
I will take your advice and try to merge the pieces together as a whole. Boolean it.
Thanks for all your help.
Re: The model problem of convergence for help [message #44086 is a reply to message #43922 ] Wed, 15 February 2012 14:32 UTC Go to previous messageGo to next message
Are you updating the existing item by going into edit mode and clicking update model?
If yes, try uploading as a new item, under create, upload.
Re: The model problem of convergence for help [message #44088 is a reply to message #44058 ] Wed, 15 February 2012 14:50 UTC Go to previous message
You first will get an email that says that "the model uploaded successfully".. part of that email says "we will now check over it looking for any problems". This first email is nothing more than a notice that the file has been sent to their server.
It's the second email that will tell you of any problems.
Previous Topic:too many shells, how do I fix
Next Topic:Blackberry phone cover
