Home » Community » General Discussion » Material Glass
Material Glass [message #43201] Tue, 31 January 2012 09:36 UTC Go to next message
avatar Novastar Design  is currently offline Novastar Design
I was wondering if people are using the material glass, because i not see pictures in the forum section 'it arrived'...
Could it also be a good material for making jewelry and rings? I would like to know if someone have experience with this
Greetz Novastar
Re: Material Glass [message #43301 is a reply to message #43201 ] Wed, 01 February 2012 17:39 UTC Go to previous message
When considering the use of SW printed glass for jewelry designs it is really important to realize that this material is brittle and fragile when compared to metal and plastic. A design that works in metal, like a flat band finger ring 2-3mm thick will almost certainly NOT be durable enough to survive use when made in the glass print media.
Tiny connection rings with 1mm wall thickness will break off VERY easily. This material can and will work but designs need to be robust and well considered otherwise you are wasting your money.
Flat pendants 1.5mm thick with frilly design elements are about as strong as crystalized sugar and simply will not withstand the rigors of real world applications. So when designing remember IT"S GLASS, duh!
-G
Leonardo da Vinci
Previous Topic:Which axis is "up"?
Next Topic:SLS NYLON
