Home » Support » 3D Design » Material
icon5.gif  Material [message #42859] Fri, 27 January 2012 09:23 UTC Go to next message
avatar LarsAndren  is currently offline LarsAndren
I got the recommendation to use a material for a prototype:
ABS-M30 0,254 mm natur
ABS-M30 0,178 mm natur
Confused
What is similar to this in Shapeway´s when order?
All best
Lars
Re: Material [message #42860 is a reply to message #42859 ] Fri, 27 January 2012 09:32 UTC Go to previous messageGo to next message
Hi there,
I see those are alternative materials for stratasys FDM printing.
Shapeways currently does not offer ABS (anymore)
Depending highly on the application the Strong&Flexible could suit your needs, but it does have different properties compared to FDM ABS.
What exactly do you need?
Stijn
[Updated on: Fri, 27 January 2012 09:33 UTC]
Re: Material [message #42864 is a reply to message #42860 ] Fri, 27 January 2012 10:17 UTC Go to previous message
Hi Stijn Smile
For this first part there are not really much advanced property's needed
I need some flexibility and one "interlock" point were there could be some force /stress (see Pdf)
smooth fit between parts needed
no heat,water resistance etc.
Cheersssss
[Updated on: Fri, 27 January 2012 10:19 UTC]
Previous Topic:Could this model be printable ?
Next Topic:Ring turning into solid?
