Home » Support » 3D Design » Could this model be printable ?
Could this model be printable ? [message #42782] Thu, 26 January 2012 06:43 UTC Go to next message
avatar EdJohnnyBoy  is currently offline EdJohnnyBoy
I am new to the process of making a 3d object printable and using netfabb and these programs.
The model i have built in minecraft. With the program mineways i have created the *.wrl file.
Then with Meshlab converted to a *.stl file. This file uploaded to Shapeways.
http://www.shapeways.com/model/452072/amphitheatrum_flavium_ __2004_cm____.html
It seems to work.
But a Customer Service Agent found some difficulties with the model. After i sent her the the models *.stl file.
This is what she says: "As you can see on my attachments, you can see that these models are too small to be printed and there fore the wall thickness is also too thin. " - her picture:
http://i1237.photobucket.com/albums/ff467/EdJohnnyBoy/shapeways/model11.jpg
After her suggestion to use netfabb i get these informations:
http://i1237.photobucket.com/albums/ff467/EdJohnnyBoy/shapeways/forshapeways.png
the model on the website
Should i let someone try to purchase the model and see what shapeways says, if its printable or not ?
But I would reluctantly make someone an offer that probably can not be met.
[Updated on: Thu, 26 January 2012 06:45 UTC]
Re: Could this model be printable ? [message #42785 is a reply to message #42782 ] Thu, 26 January 2012 07:14 UTC Go to previous messageGo to next message
The dimensions of the model on the model page are different to the dimensions shown in your screenshots. Did you update the model?
Re: Could this model be printable ? [message #42797 is a reply to message #42785 ] Thu, 26 January 2012 12:51 UTC Go to previous messageGo to next message
Yes, i have updated the model but the numbers of the dimensions i have not changed. I only changed some blocks in Minecraft and i have had to go through the repair process.
And now that you mention it, I realize that they are the same numbers that differ only in their zero points.
Maybe this happens because i choose on the uploadpage "Meters" in the "Unit of Measure", maybe, i dont know.
Re: Could this model be printable ? [message #42849 is a reply to message #42797 ] Fri, 27 January 2012 03:51 UTC Go to previous message
One of the dimensions of this model is 0.442
Uploaded as millimeters.. that's microscopic.. way too small.
Uploaded as inches.. it's still too small.
Uploaded as meters.. it's 17 inches.. too big for the printer.
Your best bet is to use Netfabb's "SCALE" command and increase the size a bit.. then upload as millimeters. A scale factor of 250 would put you at about 4 inches across.
Previous Topic:Crossing the "Thin Line"
Next Topic:Material
