| Triangle Segment Size [message #42495] Sun, 22 January 2012 15:10 UTC |
I am very much a newbie at this and am unsure how to even discribe it.
I am drawing in AutoCAD 2002. The parts I am drawing will eventually be patterns for sand casting Live Steam Locomotive parts using brass and cast iron.
When I export the parts to an STL file format the curved faces have large triangular facets in the curves.
For one will these facets show up in the actual RP part and if so can anyone give me advice on reseting my AutoCAD to a higer density on the export to STL
| Re: Triangle Segment Size [message #42499 is a reply to message #42495 ] Sun, 22 January 2012 16:36 UTC |
I don't know AutoCAD, but I do know the materials Shapeways offers.
As a general rule of thumb, aim for faces on curves that are half the minimum detail size. i.e. A 2mm diameter cylinder printed in WSF, 60 edges around the circumference and 1 edge for the height ( = 120 triangular faces for the cylinder walls) this works out to be just over 0.1mm edges on the curved areas. (with FUD, aim for 0.05mm)
The limit for (regular) upload is 1 million triangles, surfaces constrained to the regular axis of a model should be ok at whatever size triangle, however surfaces that transistion from one axis to another or are on a diagonal need to be pretty detailed to avoid 'printer stepping'... so the more triangles you can get into your model the more accurate the final print will be to your model.
[edit] sorry, I forgot my manners. Welcome to Shapeways!
A handy tip when modelling, turn off all smoothing - smoothing is a visual thing for us human-beans, printers cannot see
[Updated on: Sun, 22 January 2012 16:40 UTC]
| Re: Triangle Segment Size [message #42506 is a reply to message #42499 ] Sun, 22 January 2012 20:20 UTC |
Thank you for the help.
Sadly I am not educated enough yet to understand all you have said.
The part I uploaded is is a tapered cylinder that is 3.5 inches in diameter and one inch high
Where can I find a definition of WSF?
| Re: Triangle Segment Size [message #42522 is a reply to message #42521 ] Mon, 23 January 2012 02:57 UTC |
Thanks.
So as I understand this I need to increase the number of Facets up to the max allowed of one million.
| Re: Triangle Segment Size [message #42525 is a reply to message #42522 ] Mon, 23 January 2012 03:19 UTC |
WSF has a "minimum detail" size of 0.2mm
I would suggest designing with at least 1/2 or 1/4 of that size as your maximum. You don't want to be bigger than that or your facets are going to show.
| Re: Triangle Segment Size [message #42550 is a reply to message #42545 ] Mon, 23 January 2012 14:31 UTC |
There is no need to change any dimensions to increase the facet count. Facets are just how the model is rendered on-screen; the actual geometry is true to your numerical dimensions. However, when you export a mesh to print, only the facets are exported. You want to reduce the size of the individual facets to create a smoother appearance on your round surfaces. As mentioned above, ideally you will reduce the facet size to something smaller than the print resolution.
I don't know specifically how to change your facet resolution in AutoCAD, but Google sent me here: http://books.google.com/books?id=I49AEJAsa98C&lpg=PA352& amp;ots=2N5mrKzUuu&dq=facet%20autocad&pg=PA352#v=one page&q=facet%20autocad&f=false
Might be a good place to start.
| Re: Triangle Segment Size [message #42568 is a reply to message #42545 ] Mon, 23 January 2012 17:40 UTC |
If you like, I can adjust your model for you to increase the face count & smoothnes without changing the size - I'd need an obj or stl file and it wouldn't take more than 10 minutes.
| Re: Triangle Segment Size [message #42657 is a reply to message #42629 ] Tue, 24 January 2012 16:20 UTC |
Looks smooth now.
If you open a new file and change all of these system variables plus all your layers etc. you can save this as a drawing template file '.dwt', then when you come to open a new drawing all these variables will already be set.
If ever you get stuck with Autocad give me a call. Always pleased to help.
jacantdesign@gmail.com
