Home » Community » General Discussion » Model discription layout
Model discription layout [message #42435] Sat, 21 January 2012 15:29 UTC Go to next message
avatar Novastar Design  is currently offline Novastar Design
Hi
I wonder how i can change layout of the model description. Wenn i type something now, everything is saved without enters ect...
i see other model descriptions where they figured how to do it..
I also like to know how you can make a link in the description to another model.
Hope someone can help me out
Thanks Novastar
Re: Model discription layout [message #42447 is a reply to message #42435 ] Sat, 21 January 2012 17:14 UTC Go to previous messageGo to next message
All is in HTML now. More powerful but also less intuitive.
Here is the code of the begining of this description
<strong>D13 Sphere
  <br><br></strong>This is a Truncated Sphere D13. It has a 4-fold symmetry.
<br><br>This die is inspired by the
<a href="http://members.ozemail.com.au/~llan/mpol.html">repulsion force polyhedra</a>. But in this case, the underlying polyhedron (not rounded) does not exactly look like the shape that can be obtained through this technique with 13 points repulsing each others.
<br>Instead, I calculated the positions of those points to have a maximal radius for the circles resulting from the intersection of this underlying polyhedron with a sphere. The result is a truncated sphere with 13 circular faces of same radius.
<br>
Basically, <br> is used to go to the line (enter), you can put as many of them as you want.
For the links you must use <a href="adress of the link of your model">name of your model</a>.
Re: Model discription layout [message #42448 is a reply to message #42447 ] Sat, 21 January 2012 17:22 UTC Go to previous message
aha thanks !!
and i can copy and edit this in the description...
i will try right away...
Previous Topic:Add to cart not working!!
Next Topic:FD and FUD questions
