| Sketchup Plugin - please test! [message #41514] Mon, 09 January 2012 15:05 UTC |
Hi all,
I came across the two plugins for Google Sketchup:
Manifold
http://forums.sketchucation.com/viewtopic.php?p=218691
From the description:
| Quote: | When run...
It removes 'non-face/non-edge' entities.
It removes 'disconnected geometry'.
It removes 'unfaced-edges'.
It runs an initial 'health-check' and reports.
It removes face 'flaps'.
It heals 'holes'.
It removes 'internal faces'.
It orients all faces consistently to face 'outwards'.
It erases 'coplanar edges' [optional].
It 'triangulates' all of the faces [optional].
It highlights major errors.
Solid inspector
http://forums.sketchucation.com/viewtopic.php?f=323&t=30 504
| Quote: | a tool that checks if Groups or Components are solids or not, highlighting holes or areas or errors.
They both sound quite useful. Are there any seasoned Sketchup users here who could give them a try and let me know how well it works for Shapeways?
[Updated on: Mon, 09 January 2012 15:07 UTC] Community Manager Europe | Shapeways
| Re: Sketchup Plugin - please test! [message #41526 is a reply to message #41514 ] Mon, 09 January 2012 18:05 UTC |
I couldn't use Sketchup for 3D printing without Solid Inspector...its a must-have, imo.
Manifold works on simple models, but not very well on anything where an automated solution would really help. I have yet to find any plugin for automatically fixing errors that works well - its seems to be hard for software to figure out what faces to keep, and which to delete...plus they can take a looooong time to run.
There is one plugin called Cleanup (by the same author as Solid Inspector, so its a good one) that is very useful to clean messy models, but it doesn't do all the work for you.
-Marcus
| Re: Sketchup Plugin - please test! [message #41528 is a reply to message #41514 ] Mon, 09 January 2012 18:34 UTC |
It looks like you have to become a member to download the files.
| Re: Sketchup Plugin - please test! [message #41530 is a reply to message #41514 ] Mon, 09 January 2012 18:47 UTC |
I too will reccommend the Solid Inspector plug-in, without it Sketchup would be near impossible to use for Shapeways.
| Re: Sketchup Plugin - please test! [message #41754 is a reply to message #41530 ] Thu, 12 January 2012 12:31 UTC |
Thanks for your help!
| Re: Sketchup Plugin - please test! [message #41894 is a reply to message #41529 ] Fri, 13 January 2012 21:35 UTC |
Not just free, but an extremely valuable resource. There are tons of tutorials, guides, plugins and active users.
http://fracturedmesh.blogspot.com/ - my 3d modeling blog
| Re: Sketchup Plugin - please test! [message #41920 is a reply to message #41895 ] Sat, 14 January 2012 04:07 UTC |
I tried Manifold out on one of my Sketchup models in progress... Went outside to get some food, came back, and saw that Sketchup had crashed. At this point, I think an automatic manifold-creator is just one of those things that just isn't there yet. It's one of those areas where planning, effort, and prevention are better than a barrel of cure.
| Re: Sketchup Plugin - please test! [message #41923 is a reply to message #41514 ] Sat, 14 January 2012 06:43 UTC |
The Solid Inspector seems to work okay, but I think it's giving false positives. It circles thin air and objects that don't appear to have any problems. I've run health checks and everything comes out fine.
It does help a lot with the problems it does find though.
| Re: Sketchup Plugin - please test! [message #41940 is a reply to message #41923 ] Sat, 14 January 2012 14:24 UTC |
I've never had a false positive...usually you have to zoom waay in to see the problem.
How do you run a health check?
-Marcus
