Our Gift to You: 20% off your own designs in Strong & Flexible Plastic through Dec 23, with promo code MY2014 · details
Home » Support » 3D Applications » Troubles with a model from Sketchup
Troubles with a model from Sketchup [message #3457] Fri, 20 March 2009 20:04 UTC Go to next message
avatar RSK1992  is currently offline RSK1992
Good evening.
I tried to upload the *.dae file that I exported from Google Sketchup Pro 6, and whatever I try; I get this message every time:
"There was an issue with uploading your model to Shapeways. Your model has inverted normals in it.
Normals tell us what the inside and outside of your model are(a good thing when we want to be able to 3D print your model). All the normals in your model have to be pointing in the right way. Inverted normals are also known as mixed normals or invalid normals.
The fix for this depends on what kind of software you are using. With almost all packages you can easily visualize the normals so you can see whats wrong. Some packages have an automatic filter that can "flip", "invert" or "recalculate outside" and help correct this problem for you in a flash."
I tried lots of things, but nothing really works. Can anyone tell me what to do?
Re: Troubles with a model from Sketchup [message #3459 is a reply to message #3457 ] Fri, 20 March 2009 20:35 UTC Go to previous messageGo to next message
avatar AO  is currently offline AO
Upload it and somebody will check it for you.
Greetings AO
Re: Troubles with a model from Sketchup [message #3461 is a reply to message #3457 ] Fri, 20 March 2009 21:41 UTC Go to previous messageGo to next message
Okay, well here it is. Cool
Re: Troubles with a model from Sketchup [message #3466 is a reply to message #3461 ] Sat, 21 March 2009 08:03 UTC Go to previous messageGo to next message
Hi RSSK 1992,
I tried to open it in Rhino, Solidworks, accutrans and meshlab. I guess its sketchup.
I've to install that one too.
Can you upload an stl, step or iges?
Greetings AO
Re: Troubles with a model from Sketchup [message #3467 is a reply to message #3466 ] Sat, 21 March 2009 09:10 UTC Go to previous messageGo to next message
Sketchup doesn't offer the possibilities to export it to such a file. It does to *.dae. Since that's a filesize accepted by Shapeways, I made it, but it gave the error I mentioned. Hereby the .dae file.
Greetings, Robin
Re: Troubles with a model from Sketchup [message #3468 is a reply to message #3467 ] Sat, 21 March 2009 11:31 UTC Go to previous messageGo to next message
Robin,
I can't open the .dae. I tried a few even blender refused.
The type of dae is not supported.
I found these pages where you could find something on making an stl in sketchup.
[www.ohyeahcad.com]
[www.ccim.nl]
and [www.crai.archi.fr] (search for "su2stl.rb").
Greetings AO
icon8.gif  Re: Troubles with a model from Sketchup [message #4247 is a reply to message #3468 ] Mon, 04 May 2009 18:33 UTC Go to previous message
avatar visakhm  is currently offline visakhm
so this is my first shot at 3d printing. did my model in SKETCHUP 7. and when I uploaded it I got the same message as the one above ( " Your model has inverted normals in it."). Firstly I dont know if there is a way to check this in sketchup. Now I know its a pretty complex model, its meant to work as a smaller part of a sculpture.
would be great if someone could help me out here. attaching along a STL file for the same.
BTW there is a plugin for sketchup called CADspan that can do a STL export.
http://www.cadspan.com/tools
thanks a bunch folks
v
Previous Topic:Fix Found for Export Bugs in XSI 7.0+
Next Topic:3D App with 2D import feature
