Home » Support » 3D Design » newbie - need help seriously
newbie - need help seriously [message #41092] Mon, 02 January 2012 23:29 UTC Go to next message
avatar kunlun121  is currently offline kunlun121
For a school assignment I need to have a small part printed. I designed it in 3D using Sketchup. On the tutorials section of the Shapeways website there are instructions for working with Sketchup models. I downloaded and installed Meshlab and Accutrans and followed the instructions. My model apparently has holes. It keeps having holes after redesigning several times. It has cost me many hours to redesign this thing over & over again. Frown
Then I found and followed the instructions on the tutorials website for fixing a 3D model for printing using Netfabb. That seemed to work well. I end up with a single shell with no holes and nothing in red. So I save.
Here are the problems: re-importing the file back into Sketchup shows randomly huge dimensions (1000x as big as it should be). Importing the file in Accutrans shows thousands of holes.
I am at a loss. I would really like to upload my design to Shapeways soon to get it printed in time. Would appreciate help with this. At this point I'm willing to pay a designer to get this done.
Thanks for looking into this.
Re: newbie - need help seriously [message #41097 is a reply to message #41092 ] Tue, 03 January 2012 01:58 UTC Go to previous messageGo to next message
Hi, it sounds like you are having some of the same problems other Sketchup newbies have. Its not too hard once you know what to do.
I use Sketchup exclusively for my designs and never need any other software like Netfabb, however there are a couple of free Sketchup plugins(addons) I can't do without.
The first is Solid Inspector. Use this to find holes and other problems in your model.
The second is SKP to STL. This allows you to export to STL directly from Sketchup. Use this if the DAE export from Sketchup doesn't work well with Shapeways.
Here's a thread that you may find useful where I helped another Sketchup user fix his model.
If you still want to pay someone to help you, feel free to PM me, and I'll get you fixed up in a jiffy! Smile
Good luck,
[Updated on: Tue, 03 January 2012 01:59 UTC]
-Marcus
Re: newbie - need help seriously [message #41110 is a reply to message #41092 ] Tue, 03 January 2012 12:05 UTC Go to previous messageGo to next message
kunlun121 wrote on Mon, 02 January 2012 23:29
When netfabb says the file is alright... why don't give it a try, and upload it to Shapeways ?
Re: newbie - need help seriously [message #41115 is a reply to message #41092 ] Tue, 03 January 2012 13:37 UTC Go to previous messageGo to next message
Hello Marcus,
Thank you for the excellent explanation. It worked out perfectly. The plugins were easy to install & did their advertised functions well.
I had no idea about those inverted faces. Thanks for that too. There were holes where I had performed a follow me move with a circle along a curved line. The line consisted of several elements, some straight some curved. At the joints of the line the follow me tool for some reason had problems. I had used the pull tool to close the gaps with nothing more than the screen as a visual aid. Didn't fit.
I started over and now it's all solid. Accutrans says it's ok, so it must be fine. Will upload now.
Thanks again!
Re: newbie - need help seriously [message #41131 is a reply to message #41115 ] Tue, 03 January 2012 17:52 UTC Go to previous message
Great, glad it worked out!
-Marcus
Previous Topic:Why is my design so expensive to print?
Next Topic:How to make my models cheap?
