| Multiple Materials [message #40415] Sat, 17 December 2011 16:28 UTC |
I created a model with 2 different materials (one with transparency and one with sandstone), is it possible to print them in one model like this below?
Thanks in advance!
Riddle, riddle riddle...
| Re: Multiple Materials [message #40436 is a reply to message #40429 ] Sun, 18 December 2011 11:39 UTC |
This would be the best option. Take the FCS part and make a small box for it to sit in, then use a clear epoxy or polyurethane to encase it.
Otherwise there's two other ways of producing a "different" colour inside a clear part using 3DP.
- SLA: Using a clear material you can "overcure" sections by scanning it with the laser multiple times (or using higher laser powers/different infill param's). I've seen parts with 10 different shades of yellow incased in a clear shell.
- Objet: Using VeroClear as the outer material, and any of the other Objet materials for the bug inside. Only a Connex printer is technically capable of this.
Shapeways doesn't offer either of these processes, but hey, the more you know
| Re: Multiple Materials [message #40583 is a reply to message #40415 ] Wed, 21 December 2011 16:47 UTC |
If you don't mind the interior model being white, you can exploit the wax support material in FUD like I did with my Kraken in Crystal - the squid is a wax filled hollow space within the block of FUD
