| Paint & Adhesive [message #40077] Sat, 10 December 2011 19:42 UTC |
My first post!
Does anyone out there have experience of using paint and adhesive on their models? (I think I will mainly be using White Strong Flexible polished).
My project(s) require my small* 3D printed parts to be fixed to a range of materials including plastic, wood and brass, and are then overpainted.
*typically less than 5mm x 5mm x 8mm
What type of paints work, or don't?
What type of adhesives work, or don't?
If anyone has had a similar requirement, knowing what was succesful would be extremely useful.
Thank you.........
Modelling the Great Central Railway & Metropolitan Railway
| Re: Paint & Adhesive [message #40123 is a reply to message #40077 ] Mon, 12 December 2011 07:22 UTC |
I haven't attached any of my prints to wood but i've done plastics and metal many times. I generally print in WSF without polishing. I do a lot of miniature wargaming bits that are about the sizes your are describing.
The material is a soaks up paint quite well so I generally start by dipping it in Future Floor polish (acrylic floor polish by S.C. johnson). For glue I use traditional CA glue, essentially fancy super glue. As with all glues you have to hold it for a few seconds before it bonds. Because WSF soaks up stuff I seal it before I glue but thats a personal choice not really a requirement.
[Updated on: Mon, 12 December 2011 07:22 UTC] Check Out my blog dynath.blogspot.com
| Re: Paint & Adhesive [message #40294 is a reply to message #40123 ] Thu, 15 December 2011 12:14 UTC |
Thank you.
I imagined it would be something like that. I posted the question as i have not received my first order yet, so could not experiment myself
David
