| Private sale link does not work [message #40060] Sat, 10 December 2011 15:20 UTC |
I created a model and set it as "Private, but available for sale using your private link". I then copied the Permalink underneath the model photo. Sent the link to the customer and was told the link did not work. Sure enough, tested it myself by logging out and it didn't work. Copying the full URL did not work either.
I have now had to change the setting to "Public and available for sale" to get the link to work.
This is not good since I want to leave the customer with a private link which she can come back to later and re-order, and I definitely don't want "the public" seeing this model for sale since it will mean nothing to them.
Shapeways, please address this.
Glenn
| Re: Private sale link does not work [message #40062 is a reply to message #40061 ] Sat, 10 December 2011 16:27 UTC |
Well, I copied the entire URL so it should have been.
Now, when you tested yours did you log out first? In the past I'm pretty sure I checked this but I was logged in at the time.
Glenn
| Re: Private sale link does not work [message #40063 is a reply to message #40062 ] Sat, 10 December 2011 16:35 UTC |
I've just re-tested this on another model and, as I suspected above, IF you are LOGGED IN the links work fine. LOG OUT and try them. Neither the Permalink nor the full URL works for me if the model is set to "Private but available for sale".
Glenn
| Re: Private sale link does not work [message #40066 is a reply to message #40064 ] Sat, 10 December 2011 17:04 UTC |
Yes, the link did work - was that Private but for sale? - and yes, I did switch off editing.
Very strange. I will be testing again from home later.
Glenn
[Updated on: Sat, 10 December 2011 17:05 UTC] Glenn ------ My Website Third Dimension Jewellery
| Re: Private sale link does not work [message #40080 is a reply to message #40066 ] Sat, 10 December 2011 19:50 UTC |
Yes, that's "private, but available for sale using your private link".
And as I can see in my Inbox, the full URL from an other private-but-buyable model from a current project works for the client.
Sorry, the idea about the edit mode was my last straw.
| Re: Private sale link does not work [message #40081 is a reply to message #40060 ] Sat, 10 December 2011 20:10 UTC |
[deleted]
Was doing more tests and getting thoroughly confused between URLs when logged in and not.
[Updated on: Sat, 10 December 2011 20:22 UTC] Glenn ------ My Website Third Dimension Jewellery
| Re: Private sale link does not work [message #40082 is a reply to message #40081 ] Sat, 10 December 2011 20:15 UTC |
Think I got it sort of solved. Sometimes when I logged in after having entered the URL the page would open up without the FULL URL being in the address bar. I suppose I might have been copying this at some point.
However, the Permalink does NOT work, no matter what I do.
Glenn
[Updated on: Sat, 10 December 2011 20:32 UTC] Glenn ------ My Website Third Dimension Jewellery
| Re: Private sale link does not work [message #40086 is a reply to message #40082 ] Sun, 11 December 2011 00:13 UTC |
| lensman wrote on Sat, 10 December 2011 20:15 | However, the Permalink does NOT work, no matter what I do.
Conceptual, that seems correct to me.
Let's say we have a model which was public and buyable for some time.
Let's say someone saved the permalink and/or the URL during this period.
Then, one day, the designer decides to make the model private, but still buyable (for whatever reason^^).
The permalink (and the "standard full URL" (www.shapeways.com/model/ModelNumber/ModelName) ) will stop working, but the designer will still be able to share the private link (i.e. the full URL, including the "key-part").
| Re: Private sale link does not work [message #40093 is a reply to message #40086 ] Sun, 11 December 2011 05:41 UTC |
Hhm, yes, that logically would make sense. But it begs the question, why bother having the permalink at all if it doesn't work?
Glenn
| Re: Private sale link does not work [message #45210 is a reply to message #40093 ] Sat, 10 March 2012 07:41 UTC |
Private link doesn't work for me either. I tried it with the key part.
I set my model to private for sale.
Has anyone actually gotten this to work?
| Re: Private sale link does not work [message #45236 is a reply to message #45210 ] Sat, 10 March 2012 13:10 UTC |
It looks like private links have been broken somehow in yesterday's update, as they worked the other day - I've left a notification about this issue in the right place.
| Re: Private sale link does not work [message #45388 is a reply to message #45236 ] Tue, 13 March 2012 02:13 UTC |
A customer told me today that he was able to see the private link, but was unable to add the item to his cart. I had to change it to public to allow him to add it.
| Re: Private sale link does not work [message #45429 is a reply to message #40060 ] Tue, 13 March 2012 18:37 UTC |
Exactly the problem I just had. Thankfully I saw your post first and have hopefully quickly corrected the problem.
Glenn
