Home » Community » General Discussion » WORKFLOW!!
WORKFLOW!! [message #39569] Wed, 30 November 2011 08:54 UTC Go to next message
avatar goido  is currently offline goido
I was wondering what is the correct way to work with your model, I know that modelers are using Netfabb, meshlab and Blender to correct and upload files for 3d printing. Is there a particular order? I had a model with lots of overlapping and intersecting geometry that was fixed rather rapidely by a modeler,is there a particular workflow?
Thanks.
Re: WORKFLOW!! [message #39609 is a reply to message #39569 ] Wed, 30 November 2011 20:58 UTC Go to previous messageGo to next message
avatar christopherlowe  is currently offline christopherlowe
as in most things there is not just one way to do things. some like to work in one way some in another.
there are really 3 fast and true rules
1. minimum wall distance as per the material that you are printing in and...
2. no 2 points, polygons, or lines may occupy the same space.
- you can have overlapping "shells" or "objects"
3. all shells or objects must be watertight.
please visit my blog at...
Re: WORKFLOW!! [message #39610 is a reply to message #39609 ] Wed, 30 November 2011 21:03 UTC Go to previous messageGo to next message
So intersecting is similar to inverted normals?
Re: WORKFLOW!! [message #39611 is a reply to message #39610 ] Wed, 30 November 2011 21:31 UTC Go to previous messageGo to next message
not really. inverted normals would indicate a non watertight shell. either way that isn't good.
what i meant by non intersecting points is... say you have 2 shells but they have 1 polygon in common... that will make the printer go -bleh!
Re: WORKFLOW!! [message #39613 is a reply to message #39611 ] Wed, 30 November 2011 21:48 UTC Go to previous messageGo to next message
Thanks, I will have to Google how to fix all this in Blender, I still I am not sure what is the difference between Meshlab and Netfabb in relation to uploading models to Shapeways.
Re: WORKFLOW!! [message #39615 is a reply to message #39613 ] Wed, 30 November 2011 22:02 UTC Go to previous messageGo to next message
they will fix ill developed models. there are ways to fix these things in blender without them.
Re: WORKFLOW!! [message #39617 is a reply to message #39615 ] Wed, 30 November 2011 22:09 UTC Go to previous message
I got a green model in Netfabb ( fixed model) but it was bad for shapeways.
Previous Topic:Specifying material Full Color Sandstone
Next Topic:I got blogged .. on designer spotlight at fabberforge.com
