| how many points make a ring "round"? [message #39298] Sat, 26 November 2011 18:05 UTC |
i'm using sketchup to build a ring. How many sides do you need so that a circle is actually felt and seen like a circle?
The default setting in sketchup is 24 sides, which looks not really round. 200 sides makes my pc really slow if i turn the circle into a 3d object (with the follow me tool)
Do i need more or is 200 enough? Or are there other techniques to make things round?
| Re: how many points make a ring "round"? [message #39303 is a reply to message #39298 ] Sat, 26 November 2011 19:55 UTC |
The real question is how big around is your object, and what material are you designing for? 16 faces on a 1mm post may seem nicely circular, whereas 2000 faces on a 10cm surface may still seem faceted.
I have a bit more of a writeup here about it..
http://stonysmith.com/wired/scaling.asp
| Re: how many points make a ring "round"? [message #39304 is a reply to message #39298 ] Sat, 26 November 2011 20:12 UTC |
thank a lot Stonysmith. I'll just go for the maximum 200 sides, this should hopefully do it for such a small object as a ring.
