Home » Community » It arrived! » Reed manifold for Vespa
Reed manifold for Vespa [message #3265] Sat, 07 March 2009 01:11 UTC Go to next message
avatar oopsclunkthud  is currently offline oopsclunkthud
This is a manifold to fit a yamaha blaster reed block onto a vespa. I started the design about 3 years ago but had no way to make it take physical form till now.
everything fits really well, quite happy with the results.
index.php?t=getfile&id=302&private=0
rendered fit on cylinder
index.php?t=getfile&id=303&private=0
reed block and manifold
index.php?t=getfile&id=304&private=0
reed block in manifold
  • Attachment: Picture 2.jpg
    (Size: 60.09KB, Downloaded 1187 time(s))
  • Attachment: IMG_1499.jpg
    (Size: 14.81KB, Downloaded 1196 time(s))
  • Attachment: IMG_1496.jpg
    (Size: 13.17KB, Downloaded 1163 time(s))
[Updated on: Sat, 07 March 2009 01:14 UTC]
Re: Reed manifold for Vespa [message #3267 is a reply to message #3265 ] Sat, 07 March 2009 17:20 UTC Go to previous messageGo to next message
I think you are the first who is trying this at Shapeways (at least that I am aware of).
Could you elaborate on your project ? Also how the end result was?
regards,
Peter
Re: Reed manifold for Vespa [message #3276 is a reply to message #3265 ] Sun, 08 March 2009 03:13 UTC Go to previous messageGo to next message
The manifold I'm running right now will only take a 24mm carb. With the new one I'll be able to run a 28-32.
This first print was to verify that everything fits. The reed block fit perfect but I found that I didn't leave enough clearance around the heads of the bolts. I also realized that having the bolts countersunk was a bad idea as it will be harder to make a mold from and would be almost impossible to clean up any casting flaws. I also think I can thin the walls down a bit.
My original plan had been to investment cast it in aluminum but I may be able to get away with running the SWF. Nylon holds up well to gasoline though I still need to check the temperatures in this area. If I decide to cast it I'll scale it up to account for shrinkage and send the print out for casting.
Re: Reed manifold for Vespa [message #3288 is a reply to message #3276 ] Mon, 09 March 2009 21:05 UTC Go to previous messageGo to next message
thanks for the explanation. I have seen race cars use WS&F (nylon) for intake manifolds so it can stand quite some heat. Whether it would work in your case I do not know.
Keep us posted, it is certainly a cool project.
regards,
Peter
Re: Reed manifold for Vespa [message #3289 is a reply to message #3288 ] Mon, 09 March 2009 22:11 UTC Go to previous messageGo to next message
avatar PeterHermans  is currently offline PeterHermans
pete wrote on Mon, 09 March 2009 21:05
I think pete might be referring to this example:
http://www.atcentre.nl/downloads/go/RM_in_automotive/ (unfortunately only in Dutch)
Also from Eindhoven Smile.
There are more examples though, motor racing/F1 is probably one of the earliest adopers of RP/RM; mostly for prototyping, testing and jigs&fixtures but RM for production parts is on the up with manifolds being very good examples. New plasic RM materials are being introduced with better properties (heat resistance, strength etc.) that will expand the use of RM for structural production parts. And don't forget the metal sintering that potentially creates parts that are stronger than if you would cast them.
What I'm still waiting for is some impossible organic manifold design, that you would not even thing of unless you had RP/RM to produce it. I'm sure you could optimise it in terms of material use (=weight) and airflow.
To bad I don't have a lot of knowledge of, let alone tools for FEA/CFD. If anyone has the tools and knowledge I would be happy to help out Smile.
Re: Reed manifold for Vespa [message #3290 is a reply to message #3289 ] Mon, 09 March 2009 22:14 UTC Go to previous message
Hi Peter,
actually no, although I know this one also.
I was referring to a design I have seen in the US where indeed they optimized the airflow and could extract a few % more due to the fact that there are no casting seems inside which disturb airflow.
regards,
Peter
Previous Topic:Holder
Next Topic:Elegant Bowl Sixties Series 1
