Home » Support » 3D Design » Fur
Fur [message #38849] Fri, 18 November 2011 19:23 UTC Go to next message
avatar steeveesas  is currently offline steeveesas
Does anyone have any ideas or had success making fur for a 3D printable model?
Any techniques to cover the geometry with hair so that the 3D print has what looks like hair?
Steve
all dolled up in straps
Re: Fur [message #38942 is a reply to message #38849 ] Mon, 21 November 2011 03:40 UTC Go to previous messageGo to next message
Anyone...?
Was thinking something like one of these:
http://anwo.com/store/grizzly_bear_toy_miniature.htm
or
http://www.tapirback.com/tapirgal/gifts/friends/bears/polar- bear-plastic-f1113.htm
[Updated on: Mon, 21 November 2011 05:38 UTC]
Re: Fur [message #38952 is a reply to message #38942 ] Mon, 21 November 2011 10:22 UTC Go to previous messageGo to next message
avatar Dotsan is currently online Dotsan
Hi have you tried, bump maps or sculpting software like Sculptris?
Regards
V
Shapeways reviews
Re: Fur [message #38967 is a reply to message #38952 ] Mon, 21 November 2011 15:23 UTC Go to previous messageGo to next message
I think bump maps don't change the geometry of your object right? They give the appearance of 3D on a 2D surface by changing the normals so the shading makes the object look 3D...? Let me know if I am wrong.
But in line with your comment I was thinking of using displacement mapping which changes the 3D geometry of your object based on an image or texture. Maybe this is what you meant? I have never used displacement mapping before but was reading about it last night.
I guess the idea is to unwrap my object and then take the resulting unmapping and color over it in an image editor something like fur streaks in black and white, then use a displacement modifier in blender...I'll play with it later.
Finally, never heard of sculptris...is it free? Do you use it? Easy to use?
Steve
Re: Fur [message #38968 is a reply to message #38967 ] Mon, 21 November 2011 15:29 UTC Go to previous messageGo to next message
Yes displacement map was what I meant. Sculptris is free, you have to play around with it to get the hang of it. Blender also has some sculpting tools.
V
Re: Fur [message #38969 is a reply to message #38968 ] Mon, 21 November 2011 15:44 UTC Go to previous messageGo to next message
Thanks for the info.
I'll try Sculptris out. Do you find Sculptris is better than Blender's sculpting tools? I have used Blender's a bit...
I have heard with ZBrush the number of polys really goes up, I imagine it's similar with Sculptris, so I'll have to be careful not to exceed the polys allowed by shapeways.
Thanks for the ideas...I'll post my results if they are decent Wink.
Re: Fur [message #38972 is a reply to message #38969 ] Mon, 21 November 2011 16:18 UTC Go to previous messageGo to next message
Sculptris is made by Zbrush, I find it more fun than Blender.
Look forward to seeing the results.
V
Re: Fur [message #39056 is a reply to message #38969 ] Tue, 22 November 2011 18:27 UTC Go to previous messageGo to next message
Scupltris has some easy going poly reduction tools built-in. In mesh view you can see the polys (triangles really) disappearing on the fly so you can pick & choose what parts of the model that won't suffer detail loss with poly reduction.
Re: Fur [message #39070 is a reply to message #39056 ] Tue, 22 November 2011 20:46 UTC Go to previous messageGo to next message
Thanks stop4stuff, I'll bear that in mind when trying out Sculptris! Should get some time to work on the sculpting once I finish some more geometry...
Re: Fur [message #41841 is a reply to message #39070 ] Fri, 13 January 2012 03:07 UTC Go to previous messageGo to next message
Well I tried a number of things, but I didn't have much success with any of them. I couldn't get a good result with the displacement map, but that may be because I gave up too soon. I bet someone with some more practice and skill could have used it to good effect.
Sculptris is really great and I am definitely adding it to my suite of tools! Thanks for the recommendation. However although some of the work I did in sculptris was pretty nice looking, it was taking too long to sculpt hairs all over the body. I saw someone in z-brush make a 'stamp' of fur and use that to cover the body, but alas I don't think sculptris has a tool like that.
So I ended up doing it the 'easy' but tedious way with some duplicating shortcuts. But in essence I placed elongated cylinders (hairs) all over my body. Here's the result.
The models are now on their way...I'll post pics when he arrives and/or once he's painted.
Re: Fur [message #43044 is a reply to message #41841 ] Sun, 29 January 2012 17:36 UTC Go to previous messageGo to next message
He arrived and he is painted!
http://www.shapeways.com/forum/index.php?t=msg&goto=4304 3&#msg_43043
Re: Fur [message #43920 is a reply to message #38849 ] Mon, 13 February 2012 09:07 UTC Go to previous messageGo to next message
avatar idtdi  is currently offline idtdi
In my opinion you should try with ZBrush, the results will certainly be satisfied
http://www.zbrushcentral.com/showthread.php?165601
Re: Fur [message #43984 is a reply to message #43920 ] Tue, 14 February 2012 05:58 UTC Go to previous message
The problem with ZBrush for me is that 3d modeling is a hobby I do every so often and I can't currently justify spending that kind of money on an aperiodic hobby. Would love to have it though.
[Updated on: Tue, 14 February 2012 05:58 UTC]
Previous Topic:Sketchup help!
Next Topic:too many shells, how do I fix
