Home » Support » 3D Applications » 3D Max Shapeways Calculator v1.1
 () 3 Vote(s)
Re: 3D Max Shapeways Calculator BETA 10 [message #28408 is a reply to message #28396 ] Tue, 31 May 2011 08:40 UTC Go to previous messageGo to next message
The path max gives you should exist,
normally it starts with "c:\users\" (yours is missing an S)
Perhaps you made a typo ? I just copied the path you gave me, but it should be the path max shows in the error.
You can try to enable hidden files to navigate easier.
[Updated on: Tue, 31 May 2011 11:56 UTC]
Re: 3D Max Shapeways Calculator BETA 10 [message #28419 is a reply to message #3223 ] Tue, 31 May 2011 13:13 UTC Go to previous messageGo to next message
avatar Sol3  is currently offline Sol3
I just checked it out and when I docked the panel it basically maximized and I couldn't see any of the viewports, and I couldn't figure out how to undock it. Neutral
Re: 3D Max Shapeways Calculator BETA 10 [message #28421 is a reply to message #28419 ] Tue, 31 May 2011 13:30 UTC Go to previous messageGo to next message
EDIT
I have fixed the beta10 file. It should be only be able to float, dock left and right now.
That's weird Smile
Did you dock it manually at the top or bottom?
Usually you can right click the docking bar (the double lines to the top or left of the calculator) to choose docking or float options.
It always used to dock at the left by default, the basics did not change.
Did you update/restore the config?
Perhaps re-running the script?
Can you try the edit config and find the "docking" value at the bottom of the file, it can be either left or right. Any other value should float it.
[Updated on: Tue, 31 May 2011 13:38 UTC]
Re: 3D Max Shapeways Calculator BETA 10 [message #28425 is a reply to message #28421 ] Tue, 31 May 2011 15:10 UTC Go to previous messageGo to next message
Thanks for updating it. I'll try it in a moment.
I manually docked it by dragging it to the left side of Max.
There was no docking bar for me to right-click on or drag the panel away from the left. Confused
Re: 3D Max Shapeways Calculator BETA 10 [message #32744 is a reply to message #3223 ] Mon, 15 August 2011 16:08 UTC Go to previous messageGo to next message
avatar jgarnham  is currently offline jgarnham
Virtox,
loved the calculator and the object properties matched those of 3DS. Excellent work, a very useful tool indeed. I even tried adding Silver to the materials list.
FWIW, I tried the calculator in the new 3DS 2012 version and I could not get the object properties either by "selected object" or "pick object" buttons. If there is anything I can do to help, let me know.
Anyway, now my problem is solved I can place an order.
John
index.php?t=getfile&id=10573&private=0
Re: 3D Max Shapeways Calculator BETA 10 [message #32745 is a reply to message #32744 ] Mon, 15 August 2011 16:38 UTC Go to previous messageGo to next message
Glad it could be of service Smile
Too bad the latest max broke it Sad
Currently I don't have access to Max 2012, so any help is appreciated Smile
Do you see any output in the "Maxscript Listener"
or any error, or just nothing..?
Does the config load properly?
I haven't been through the material list to see if things are up to date, so feel free to post any mistakes or updates Smile
Stijn
Re: 3D Max Shapeways Calculator BETA 10 [message #32791 is a reply to message #32744 ] Tue, 16 August 2011 10:34 UTC Go to previous messageGo to next message
No it's fine Virtox, I got it working okay in Max 2012 now (see below). It may have been because I ran 2012 after 2011.
I rebooted and it worked better.
It does however have an issue and the control remains open after Max 2012 shuts down that cause an error report to be sent to Autodesk.
No big deal really.
John
index.php?t=getfile&id=10594&private=0
Re: 3D Max Shapeways Calculator BETA 10 [message #32793 is a reply to message #32791 ] Tue, 16 August 2011 11:32 UTC Go to previous messageGo to next message
Hmm, strange..
Attached a version (b11) that hopefully fixes that behavior.
EDIT: For posterity sake this post will keep Beta11 attached.
Current latest is V1.1 which got a big overhaul, but it breaks compatibility with the old config.
There were just too many changes in materials and new parameters to keep it compatible.
[Updated on: Fri, 06 July 2012 21:45 UTC]
Re: 3D Max Shapeways Calculator v1.1 [message #50942 is a reply to message #3223 ] Fri, 06 July 2012 20:39 UTC Go to previous message
V1.1 is here! Get it : http://www.shapeways.com/forum/index.php?t=getfile&id=18 270
Please check the opening post for details: http://www.shapeways.com/forum/index.php?t=msg&th=714&am p;am p;start=0&
[Updated on: Fri, 06 July 2012 21:46 UTC]
Pages (2): [ «    1  2]
Previous Topic:OBJ conversion Mess
